Thread: Filter Flush - Contains Sodium Bisulfate
    Apr 2016
    Waynesboro, PA
    18
    Bought a product to clean my DE Filter Fingers, it's sold at the pool store as Filter Flush. It has "unique tracer dye", "simplifies use". I suppose this helps when you rinse it to ensure you've rinsed thoroughly. Instructions are to mix 2.5 lbs with 5 gal of water and soak for 12-24 hours. Anyone have experience using this this? The caution label says that it contains Sodium Bisulfate, but that's really the only indicator as to whats in it. Thanks!
    24' Doughboy Autumn Breeze AG - Hayward Power-Flo LX 1hp - Hayward EC40C90 Perflex DE
    ColorQ Pro7 & TF 100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Re: Filter Flush - Contains Sodium Bisulfate
    Apr 2016
    Waynesboro, PA
    18
    Thanks Richard.
    Could be, the physical description in the MSDS you posted says red to purple granular. This is red granular. Other than that the bottle doesn't give me any other hints.
    Richard320's Avatar
    Jan 2010
    19,007
    Quote Originally Posted by wawazat? View Post
    Thanks Richard.
    It's just acids. You can do the same with a clean plastic trash can and some diluted Muriatic Acid.
    I've never done anything to my DE grids but hose 'em off, so I'm no help here.
