Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: Confused pool owner
    Lucky88's Avatar
    Apr 2016
    Dubuque Iowa
    12
    Confused pool owner
    Hi this is my first time posting.
    We have owned this house and pool for 4 years.
    Obviously I still don't have a clue, but i try.
    We have a 20 x 40 in ground pool with a vinyl liner, 32000 gallons.
    Test strip tells me:
    Hardness-100
    total chlorine -3
    Free clorine-0
    ph-7.2
    alkalinity-120
    ca-0
    So far we have scrubbed the walls , vacuumed and back washed.
    We have added 18 gallons of bleach, clarifier, stabilizer, and we have a cloudy blue pool. What am I missing
    Good luck explaining it to me, I'm really trying.
    We did the BBB method last year after we got it right and did great!
    Thank you!
    Lucky88
    32000 gallon pool, vinyl liner, in ground, Dubuque Iowa, Taylor test kit Complete (Fas-dpd chlorine), Hayward sand filter
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,414
    Re: Confused pool owner
    Hi, welcome to TFP! If you were following TFP last season, then you have probably seen our advice about test kits. Having a good, high quality FAS/DPD test kit is an important part of the TFP care plan. A test kit is an investment in the quality of your pool and it will pay off in no time at all. Do not add any more clarifiers, they will not help at this point. How much stabilizer did you add and how long ago did you add it? You did not post a result for CYA and that is an important value to know. If you have over stabilized the water it will be more difficult to keep clear.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Welcome to TFP!
    Skip the clarifier and stick with these, Pool School - Recommended Pool Chemicals and use only as needed.
    Toss the guess strips in the trash and order a TF100xl from TFTestkits.net.
    This is how we clear algae from a pool. Don't skip any steps! Pool School - SLAM - Shock Level And Maintain
    And this is how we maintain pools. The good news is I only had to read it 30 or 40 times before I got it. But, the real key is just to jump in and start doing, it becomes much clearer fast. Pool School - ABCs of Pool Water Chemistry
    Apr 2013
    Sacramento, CA
    2,769
    Clarifier is not something you just dump in the pool. You use it to remove items from your water after the water is balanced and there is no bad stuff present.
    Get a test kit k 2006 is good or tf100. Give us some numbers from that.
    I suspect you have something growing in there and you will need to SLAM the pool
    Lucky88's Avatar
    Apr 2016
    Dubuque Iowa
    12
    Okay i have a Taylor test kit but don't really know how to use it.
    Its a Complete (Fas-dpd chlorine) set
    I have printed out all the info from above and will look it over.
    My biggest confusion is the cya and shocking?
    I had a pool place help me one year and I had over 1000.00 in chemicals and I still had algae. So that's when my neighbor said dump in bleach and we found the BBB method.
    Thanks for all the info, I will work on reading it and try to understand it
    Lucky88
    Flbeachluvr's Avatar
    Mar 2016
    Port Orange, FL
    363
    I'm a new pool owner and I found the step-by-step instructions in the Pool School section under Extended Test Kit Directions to be very helpful. I also watched a few YouTube videos. You can also use the advanced search feature on this forum which I have found invaluable when looking for specific topics. Good luck.
    Pool completed 3/21/2016
    8800 gallons, plaster 14' x 24', 3/4 hp Hayward pump, Hayward cartridge filter, Blue Essence T-5 SWG, Kreepy Krauly Kruiser, Taylor K-2006 test kit with Speedstir, Taylor K-1766 salt test and 250 sq. ft. of Heliocol solar panels with Pentair Solartouch control system
    Lucky88's Avatar
    Apr 2016
    Dubuque Iowa
    12
    Okay my son and I did the testing, so it might be a little off???
    CYA- less than 30
    ph-7
    alk-40
    calcium hardness-200
    free chlorine-1.8 free
    9 combined
    I hope this is what you were asking for
    Lucky88
    Mar 2016
    Port Orange, FL
    363
    I'm hoping some of the experts jump in here and give you some assistance. I know they will ask you specifically which Taylor test kit you have.
    DFW, TX
    24,509
    Add your pool info to your signature so that we can better help you, more here, Pool School - Read This Before You Post
    Numbers look good. You are ready to SLAM your pool.
    Here is the short version of instructions, Pool School - SLAM - Shock Level And Maintain
    Here is the long version
    Turning Your Green Swamp Back into a Sparkling Oasis
    Lucky88's Avatar
    Apr 2016
    Dubuque Iowa
    12
    thank you, I will read all info and get moving!!
    Lucky88
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,619
    When you post your tests do it like this:
    FC
    CC
    PH
    TA
    CH (net really needed with a vinyl liner)
    CYA
    I bet this helps!
    How to Use a Taylor Complete FAS-DPD Pool Water Test Kit K-2006 - YouTube
    For the PH I find if I hold a white, plastic plate up behind the PH test tube and pull the plate back and forth until I get a color match I get the match faster.
    For the CYA-------do not start looking for the dot. Add some water, glance, look away, add some more water, glance, look away, glance. Once you do not see the dot with a glance call it good!
    Kim
    Mar 2016
    Port Orange, FL
    363
    Quote Originally Posted by kimkats View Post
    Kim
    As I'm still new to all this too, should the dot on the CYA test just disappear or should it be entirely gone? I think I'm over analyzing this test.
    Jul 2012
    Tallahassee, FL
    30,619
    LOL I HATE the CYA test! So that ^^^^ is what I came up with..........I call it the "bar glance". You don't stare, you just glance then look away, glance again to see if they saw you looking LOL
    The dot should be gone when you GLANCE in the tube. If you stare you WILL see it even if you cannot see it LOL One person had an idea I like also. Pour it to each level and the the glance in and out. If you can see it go to the next level, etc until you reach a level where it cannot be seen at a GLANCE. Call it that level.
    Kim
    Lucky88's Avatar
    Apr 2016
    Dubuque Iowa
    12
    Okay, thanks again.
    I get really frustrated because my husband says just keep adding chlorine??? I'm like there's more to it?!?!?!
    Lucky88
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    If you have a pool heater you'll need some CH, check the owners manual....usually 225 ppm is good.
    Dolphin E10 Cleaning Robot.
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    576
    Kim
    I saw a post on here once about CYA test and was the best advice (for me anyway) ... Pour to first line... Hold down look... If needed.. Pour to next line etc....
    Has really helped me in that test lol
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
    Jul 2009
    Houston, Texas
    9,414
    How long has it been since the filter was backwashed?
    Love TFP? Become a
    TFP Supporter!
    Lucky88's Avatar
    Apr 2016
    Dubuque Iowa
    12
    Yesterday and we changed the sand filter to all new sand last year
    Lucky88
    DFW, TX
    24,509
    Here are some reference photos of the CYA test from Taylor, https://www.taylortechnologies.com/C...P?ContentID=36
  20. Back To Top    #20
    Lucky88's Avatar
    Apr 2016
    Dubuque Iowa
    12
    Thank you that was a great example.
    Lucky88
