Thread: Question on the Pool Math
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    When setting up the readings In Pool math what should i have checked in the drop down It always comes up as trichlor the default setting. I dont see a choice for Sodium hypochlorite 10.5% which is what I use from the pool store. Should I just change the first box to 10.5 from 6 and set up the rest before making adjustments??
    6100 gal. In ground pool,1HP Pentair Superflo pump, 100 sq. ft. Cartridge filter , 3" tab dispenser, Aqua-Cal heat pump system ,Baracuda MX8 cleaner, in a Birdcage,Taylor K-2006 complete FAS-DPD chlorine kit.
    "Remember Folks Freedom Isn't FREE !!!"
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: Question on the Pool Math
    On the second box to the right under FC, type in 10.5 then hit calculate.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,455
    It says
    Add __ oz of _*__ trade % bleach. Jug size _____ * is where you would put your 10.5 You will call it bleach for pool math.
    Kim
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    Thank you guys I was hoping I was doing it right all this time. I just had to ask!
    That Pool Math is a great tool !!
