Thread: Life expectancy of an automatic pool cleaner??
    Mar 2015
    Reading PA
    65
    Good Morning TFP,
    What is the expected life of an automatic pool cleaner?
    I like the simplicity of the automatic cleaners. For me to plug in, drop in, walk away and return to the pool cleaned is great.
    The only time I have my cleaner in the pool is when it is functioning. I don't like the cords and the cleaners in there with my children. I have preteens and teenagers in there playing games all the time. Besides for ease and safety - I would like to extend the life of any pool cleaner I have.
    Because of the investment of the automatic cleaners - it would be helpful to know about how long they last
    Thank you in advance for your help.
    Thanks!!
    18ft x 36ft 24500 gal vinyl liner inground
    Salt water pool - swim pure plus
    Hayward cartridge filter
    Re: Life expectancy of an automatic pool cleaner??
    Quote Originally Posted by wpturner05 View Post
    Good Morning TFP,
    Because of the investment of the automatic cleaners - it would be helpful to know about how long they last …
    That really depends on a lot of factors. My current Dolphin is about 12 years old. The first power supply failed two years ago and I picked up a used replacement on ebay. That replacement started to go screwy at the end of last season (had to switch on and off repeatedly over 30-minute period to get it cycling). The cleaner itself started to limit its movements (perhaps related to the power supply) and it bypasses large sections of the pool and struggles up walls. I've owned it for the last years and have taken good care of it but I don't know what happened in the first 9 years.
    The important thing is to treat it with care. you can pull it to the surface by its cord, but never yank it out of the pool that way. And make sure you store it on its side so the rollers don't get damaged. Otherwise its up to the pool gods. There's no reason you can't get a decade or more, but the best warranties are only 2-3 years. Some of the higher-end units tout modular repairability for easier home repairs/replacements of parts.
    I'm currently trying to figure out what to get as a replacement, hopefully by this weekend. Update: going with Maytronics S300.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Dec 2014
    Riverside California
    482
    Also, keep the power supply out of the direct sun. Heat is the enemy of anything electronic, so keep it in the shade. For longevity I remove my cleaner from the water when it is done and store it in my garage.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
