Results 1 to 7 of 7
Thread: Newbie needs help
    McJenny09's Avatar
    Apr 2016
    Garland, Texas
    1
    Newbie needs help
    I just received a slightly used above ground pool, 14x42. I have no paperwork, instructions, or hose. I've never had an above ground pool. I had an ingot do with a saltwater systems years ago. I basically need above ground pool 101. I have a 7 year old daughter who is part fish so I want to make sure I set it up correctly with all the chemistry calls I will need, etc. Please help!' Thanks! 👍
    Jun 2014
    15,008
    Re: Newbie needs help
    Alright you two, we need to get you in some water ASAP. Welcome to TFP! We can definitely help you with the chemistry, just make sure to plan for ordering the right test kit (TF-100 link below) before filling with water. If you go to the pool store for free testing, your checkbook will loose weight fast, and the results will be disappointing. Nothing is better than checking levels yourself, and it's easy!
    As for the pool and physically getting it set-up, we may be able to give you some pointers as you go. It might help if you update your signature with any of the information of the equipment and products you currently have. Maybe post some pics too. From the Home Page "Search" feature, just type something like above ground pool build, and you should also find many threads where people posted their build in stages. Some have a link in their signature as well. That may help.
    Either way, we'll do our best to help get you through it. Welcome to TFP!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    HI! We can get you all set up for your little fish! LOL She will LOVE having her own pool!
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    There are lots of threads in the Above Ground Pool forum about setting up pools. Here are a couple of good ones.
    New Pool Build Questions
    New above ground oval 18x33 install
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    We'll just send pooldv right on over there and have him knock it out for ya'! Welcome to the forum.
    DFW, TX
    24,450
    Have shovel, will travel! I usually don't make it past my pool though!
    Casey's Avatar
    SW PA
    10,423
    Welcome to TFP. I'd also YouTube some videos using generic search words like install above ground pool and leveling yard for above ground pool. You should come up with a great starting point n direct all of your questions here to TFP.
