Thread: Chem Question- CrystalPlus
    Ubrucen's Avatar
    Apr 2016
    Vancouver
    32
    I saw this product in Costco and it peaked my interest. It claims to reduce the need for chlorine up to 50%, balance PH and eliminate algae. Too good to be true? The reviews on the Costco site look great and seems like it could be a good addition to my pool upkeep? Any feedback? Link below:
    http://m.costco.ca/Crystalplus-Chlor....10313565.html
    16K IG Vinyl, Hayward Pro Series Pump, Sand Filter, Turbo Cell TCell 15, HaywardSuper Pump and 2 more pumps for for Slide, Waterfall, Powerfall, Hayward TigerShark cleaner
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Chem Question- CrystalPlus
    The first thing I saw was this warning
    Warning: Crystalplus contains copper. Excessive levels of copper, copper use not approved by Health Canada or sudden changes of pH in water can cause stains on pool surfaces. This phenomenon can also be found in pools with cement plaster, marble silicone coatings and PVC.
    I have spent countless hours helping people spend even more hours and lots of money trying to get copper out of their pools and remove stains. You don't want to be next!
    Ubrucen's Avatar
    Apr 2016
    Vancouver
    32
    So I should toss this idea to the side along with the sneakers that are supposed to tone my body while eating pizza and washing it down with a 6 pack, just by wearing them? Understood - good catch and thanks for the input
    also I'm glad to have found this site!
    38,475
    I am pretty disappointed that Costco carries the pool chemicals that they do. I would not recommend any of them.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I feel one of the worst things about copper based pool chemicals (besides the staining and green hair it causes) is the fact that while copper is an effective algaecide, it does not effectively sanitize the water from bacteria and viruses which are invisible to the naked eye. With a conventionally Chlorinated pool we use the absence of algae as a visual sign that the Chlorine is at an effective level to make the water safe from most pathogens, but once you add metal ion systems, copper, etc. into the mix you may end up with clear water that is harbouring dangerous pathogens. Think of it like all those nature shows on tv warning against drinking water in the wild, even from clear running streams, just because the water is clear does not make it safe.
