Thread: Pump makes metallic ping sound
    Dec 2014
    Rockville, MD
    78
    Question Pump makes metallic ping sound
    I just got my pump running this season. It spent the winter out in the elements and not covered. I am hearing occasional metallic pinging sounds maybe a momentary metallic scratch. I believe it is on the dry end. I checked to make sure the impeller was cleared.
    Any ideas on what this is? Should I be running it?
    I have a new variable speed pump in the box. I was going to replace it after the pool has had its spring break-in.
    Pool: 40x15ft "Mt. Lake" shaped plaster IG (30k gallons with Borates)
    SWG: Circupool Si-45
    Pumps: Hayward MaxFlo VS (SP2302VSP) + Booster Pump for Polaris 180
    Robot: Kreepy Krauly 830 || Filter: Pentair Tagelus TA-60D (Sand)
    Test Kit: TF-100 (with Speed Stir)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Pump makes metallic ping sound
    Last time mine did that there was a snail shell banging around in there.
    Dec 2014
    Rockville, MD
    78
    Was it in the impeller or in the motor housing?
    Could be debris getting in the fan. There's a fan mounted on the shaft just inside the front of the motor. There are vents in the front and back to allow for airflow. Air gets sucked into the front vents and blown out the back vents.
    Support the site
    Dec 2014
    Rockville, MD
    78
    This is interesting... I was trying to think about how to explain the sound. Water dripping on an air conditioner compressor fan came to mind. Also popcorn being made in a sauce pan. The fan may very well be were to look.
    DFW, TX
    24,483
    Snail shell in the fan at the back of the pump.
