Thread: Any builders in or near Madison, WI?
    MitchRyan912's Avatar
    Jul 2015
    Madison, WI
    330
    Please PM me if you're in the area. I need to get some quotes on getting some new equipment and have it installed. Thanks!
    2016 total pool rebuild thread: here. Pool: 26,000 gal IG vinyl liner (20'x40') in Madison, WI. Gear: ​Superflo VS, Triton TR-60 filter, 2" hi-flow MPV, & Raypak 266A heater. Testing: Taylor K-2006C. Manual chems: 12.5% NaClO liquid, granular CYA, baking soda, 31.25% muriatic acid.
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    Re: Any builders in or near Madison, WI?
    You probably don't need a builder for changing pool equipment. You can have a plumber / electrician with pool experience change out your equipment (sounds like you are looking to swap out equipment )
    Geometric pool with all Pentair equipment. Raised spa - 18" with Artic Lagoon 1" glass tiles. 3HP VS Pump, 2 skimmers, 6 returns, IC40 Salt system, Easy Touch 8 with LED color light in pool and spa. 1200 sqft of Marble White Pavers decking in Versailles pattern. Tiling and coping almost completed, Indigo Blue Prism Matrix plaster. Pool Build Thread: Houston (Katy) Pool Build - Started April 2016
    Jul 2015
    Madison, WI
    330
    There's more than likely going to be some major plumbing re-work involved with replacing the motor and/or the filter. It's not as easy as swapping out some gear.
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    I hear you...
    Jul 2015
    Madison, WI
    330
    ...and now digging up and re-plumbing the pipes from the skimmer to the equipment. Leaky skimmer line has come up as a problem to deal with.
