Thread: 1.5" or 2"
    Mar 2016
    Chicago,IL
    88
    1.5" or 2"
    Well after weeks(it seems longer) they finally got the pool installed and its filling as we speak. I had already done the electric and seems like the return/skimmer is farther away then I feel it should of been located. I bought 9' hoses to help but the return is stretched out pretty good and im not okay with it. I am
    gonna go ahead and just hard pipe it as I have worked with schedule 40 enough to know a thing or 2. I am curious if I should go with 2" though as most seem to mention it. It's only gonna be about 12-15' of pipe. it slopes down about a foot in its travel towards the pool. I just don't want to bog down my pump by oversizing the pipe either. I will obviously have some means of disconnect on the pump side but is it recommended on the pool side also?
    19k 15x36' inground oval vinyl lined pool with deep end. 3 returns , 1 skimmer, 1 main drain. TF-100 test kit
    38,305
    Re: 1.5" or 2"
    You can not bog down a pump by using a bigger pipe, that actually lowers the head loss and allows for the pump to move more water.
    I might suggest 2" on the suction line and 1.5" on the return side.
    Unless you are burying it, I might make it removable on both ends so you can ensure all the water is out for the winter.
    Mar 2016
    Chicago,IL
    88
    Re: 1.5" or 2"
    I was planning on burying it so it wasn't a trip hazard. I could also just make a small trench to put it in as the area will all be river Rock and just put level with that. If it's a better idea to have it removed for winter I will go that route
    38,305
    Re: 1.5" or 2"
    You can bury it, just want to make sure you blow it out well for the winter since at the pool sounds like the low point. Or you could add a Tee near the low point and add hose bibs or some valve in an irrigation box that would allow you to drain the water out of the pipe before winter.
    Mar 2016
    Chicago,IL
    88
    Re: 1.5" or 2"
    Thank you so much for the advise. Nothing the air compressor can't handle there
    38,305
    Re: 1.5" or 2"
    Well I am just not sure the compressor can add the air fast enough to force all the water out ... but, I live in AZ and have never closed a pool or dealt with freezing in the pipes
