Results 1 to 7 of 7
Thread: Vacuum Cleaner Type
    Jul 2015
    Aiken SC
    33
    Vacuum Cleaner Type
    Got an intex auto cleaner for my pool (22 x 54") and started to use it today. Past history is that my pool has been on the ground outside spread out to dry it out before putting it up AGAIN. Anyway, put the pool up the other day and noticed that their was grim on the side of the pool and bottom of it as well as the outside of the pool. Clean it all off the surface of the pool inside and filled up the pool. I was thinking maybe this intex auto cleaner would take care of it, but it's not. It's like a lot of debris on the bottom. So took a broom and decided if it was stuck to the bottom of the pool or not and found out it's not. So my question is, what is a good vacuum cleaner to purchase that can pick this stuff up and sand?
    Thanks
    Re: Vacuum Cleaner Type
    It's really going to depends on how much suction your pump has.
    Intex ultra frame 22 x52
    intex sand filter and pump
    intex saltwater generator
    Jul 2015
    Aiken SC
    33
    The type of pump that I have is a 3,000 GPM if that is what you would like to know.
    Jul 2015
    Port Neches, TX
    53
    we have the Intex cleaner and it really works for us. I know some people have complained about it not working, but they hooked it up to the outlet, going from the pool into the pump. It's actually supposed to be hooked to the inlet that goes from the pump INTO the pool. The one that returns the water to the pool. Is that how you have it hooked up?
    22' x 52" Intex UltraFrame ABG, 10,500 gallons
    using TF-100 test kit
    Krystal Klear 633T Filter Type B pump - 2,500 GPH
    Intex wall-mount surface skimmer
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    take a look at the Pool Rover Jr.
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    Jun 2015
    Stockholm, Sweden
    250
    Very happy with my Intex pool cleaner. It Picks up all debris, pine needles, sand etc. Sometimes misses in the corners, I have a rectangular pool, shouldn't be a problem in a round pool. It needs a good, strong pump though.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Jul 2014
    Georgia
    13
    I have Wanda the whale. For the price you can't beat it.
    16,000 gals. 27 Round AG. Intex SWG. 1.5 hp Hayward Power Flo Lx. Jacuzzi 190L sand filter. TF-100. Full sun.
