Hanging a rectangular Intex Ultra Frame Pool directly from the pool deck
Hello
Im from Sweden so sorry my bad english.
Im thinking of NOT using the metal frame that came with my pool, instead i will try hang the pool directly from the pool deck.
Because of the climate here we ned to put the studs a few feet into the ground when we build our deck, so i think its stronger than the metal frame that comes with the pool and will not sink into the ground.
I will use pressure treated wood 2x2" square studs instead of the horizontal metal bar, then it's just to bolt straight through the pool linear and let the bag " hang" in the wooden pool deck. The pool will hang on the wooden bar not the screws.
Personally I would prefer to avoid building a steel frame with corrosion problems. Especially when the salt water chlorinator is used .
Hard to describe my hope illustration will helps.
Hello
