Interesting. I was really wondering how that was going to work. Looking forward to seeing it fill! Hopefully you are able to show us a pic of what it looks like full from under the deck.
I had a few people barefoot in the pool making kicking motions with outside of foot against the wall. That was quite effective. Got rid of all the wrinkles that way.
yah you have to kick out the wrinkles before you put water in it. or use a pool brush to help knock them out. the weight of the water will make it impossible to get the wrinkles.
They have supports for the top cord -- the volume and mass of the pool water give stability to the walls. This really doesn't have a top cord, but it does sort of. I'm most concerned about the corners.
Starting day 5/25/2015 INTEX AGP 24'x12'x54" 8,400 gal, with salt and borax, INTEX 3,000 GPH pump with 16"sand filter, WM Hayward Skimmer, Intex SWG CG-28669, 1 1/2" hard plumbed PVC, Lil' Shark Vacuum With Leaf Canister, TF100 test kit, speed stir, K-1766 Taylor salt test http://www.troublefreepool.com/content/128-chlorine-cya-chart-slam-shock
