Results 1 to 9 of 9
Thread: When to stop shocking
    botanica37's Avatar
    Feb 2009
    Oakton, VA
    65
    I've been shocking my pool for full 9 days now since I opened it. I raised the FC from 0 to 16 and have kept it there. For the past few mornings, the FC would be 14 and then I would raise it to 16, same in the evening (FC 14). It seems that I lose 2ppm overnight, but my CC is 0. Should I keep the level at 16 until it stays there overnight or since the CC is O, I can assume all is well and let it go down? btw, we had a lot of rain in the past week.
    FC 16
    CC 0
    TA 80
    CH 280
    CYA 50
    Thank you!
    free form 40k gal, IG, plaster, Triton II 100C sand filter, Lite 2 heater
    1 1/2 HP Pentair Ultra Flow High Performance pump
    Caretaker in-floor cleaning system
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: When to stop shocking
    Hi. Okay, so to clarify...
    You test in the evening, and if the FC is below shock level, so you are adding more chlorine to bump it back up to 16. Are you restesting 1 hour after adding the bleach, to make sure you are reaching 16? The final number is what you should compare to the morning test.
    If not, try that. You may not have been reaching 16, and may not actually be seeing an overnight drop.
    In the morning, are you testing before the sun hits the pool?
    The criteria is 1ppm or less FC loss overnight. Anything more than that and you are still supposed to shock.
    Butterfly's Avatar
    South Carolina
    10,045
    I like Chem Geek's (Richard's) criteria of when you are done shocking:
    The process is complete when:
    A. You hold FC loss to 1.0 or less overnite
    B. Your CC's test .5 or less
    C. Your water is sparkling
    According to the CYA/Chlorine chart, shock level for your CYA of 50 is about 20 (Pool Calculator 16). You may want to bump it to 20 and see if that does the trick.
    Don't forget to brush!
    Welcome to the forum!
    You're done SLAMing when:
    botanica37's Avatar
    Feb 2009
    Oakton, VA
    65
    This morning it was 14 (that was around 8, but it is cloudy, so I am assuming the sun is not to blame for the drop), and I added a 1.82 bottle of bleach, doublechecked the count about 2 hrs later and the FC was 16.5. I never get around to double check at night after adding the bleach, but for the past week it has been fairly consistent drop and add on amount both morning and evening. I've been brushing the pool daily, sometimes twice, because I tried adding cal-hypo to bump the CH up and get the shock level, but it wouldn't disolve, so I brushed and brushed while switching back to bleach. I will try to bump the FC to 20 then and see what happens.
    rogerbrks's Avatar
    Round Rock, TX
    172
    exit stage right
    21,200 gal IG gunite, CL 580 sqft Cartridge filter, aqua pure salt system, polaris 480-blue&white, Jandy PDA Remote, (4) Jandy Deck Jets
    11,969
    Quote Originally Posted by rogerbrks
    I have seen it sparkling clear once but I was using Cal-Hypo to clorinate and of course my CH is high. Since I started using Bleach (6%) it has had a a beautiful blue shade to it. Should I be worried of an algae outbreak? I have white plaster.
    If you are having water clarity/balance issues with your pool you should begin a new thread and post a full sets of results.
    30,431
    NUMBER ONE QUESTION........How does your water look?
    If it looks good, your CC's are obviously .5 or less, and you are only losing 2ppm overnite....I would attribute that slightly excessive loss to the contaminants that have enterd your pool from the rain and let the FC come on down to 3-5ppm.
    Just to clarify, the way you confirm overnite loss is by testing in the evening and then testing in the morning with no additions in between. Your statement could indicate you're losing 2ppm daily.....I'm not sure.
    botanica37's Avatar
    Feb 2009
    Oakton, VA
    65
    I still can't get the handle on the shocking part. We had so much rain lately that almost every couple of days I had to drain the pool in the middle of the night to prevent overflowing. Keeping the FC stable overnight is just not happening, there are either too many worms in the pool after the rain or leaves/pollen/flowers. I am vacuuming and brushing daily. So far I had the FC b/n 14-20 for about 3 weeks - is there any potential downsides to keeping chlorine that high for so long?
    Should I let the levels drop to normal and wait for a dry spell to shock the pool? The water looks very nice when I use bleach and kind of murky when I use Cal-hypo, but I am assuming that is from the color of the Cal-hypo itself (nasty grayish). This morning results:
    FC 16
    CC .5
    PH 7.5
    TA 80
    CH 270
    CYA 50
    If the water is clear then you can stop shocking, but given the storms and debris you describe it would probably be best to keep the FC level a bit higher than normal until the weather clears up.
    If the water is still murky then I would continue shocking.
