Thread: Sand filter
    May 2015
    Kaplan louisiana
    68
    Sand filter
    I've got a Pentair sand dollar sand filter SD60 that I'm doing a deep clean on and after pulling the top I see that it is only 1/2 full of sand. Does this seem right?
    13500 gallon above ground with pentair sand dollar sand filter, 1.5hp pentair pump with TF-100 test kit. Kaplan, Louisiana
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Sand filter
    It does require some "freeboard" at the top of it, from memory I think for that filter it is about 10" of open space from the top.
    I have a Tagelus filter, manual here lists 10 1/4" of freeboard, but I can't find it spec'd in the sand dollar manual.
    http://www.pentairpool.com/pdfs/Tage...ntFilterOM.pdf
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    May 2015
    Kaplan louisiana
    68
    Re: Sand filter
    Thanks, just seemed weird
    30,419
    Re: Sand filter
    I think it's low. Generally, sand filters need sand about 2/3 full. The online manual should tell you.
    May 2015
    Kaplan louisiana
    68
    Re: Sand filter
    The manual said the amount of sand is listed on the filter housing which reads 250lbs. I have no way of knowing how many lbs are in my sand filter so with it being 1/2 full should I add or leave it as is?
    Re: Sand filter
    It sounds like it's no more than 15% off of the recommended level. I'd suggest not worrying about it, unless you notice a significant issue with filtration. And even if there were an issue, I would just add some DE or "Jack's Magic Filter Fiber Stuff" to improve filtration of smaller particles. But I do that anyway, so there's no additional effort.
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
