Results 1 to 8 of 8
Thread: To Drain & Fill or go Another Season
    Jun 2014
    Chandler/AZ
    51
    Currently, my CH is at 800. Last year at this time, CH was 500. The last time I did a D&RF was 2 years ago. Fill water CH ranges from 170-200. It appears that I'm picking up about 300ppm/yr.
    Today's numbers are:
    FC: 5.0
    CC: 0
    pH: 7.97 (dropped to 7.5 just after test)
    TA: 80 (should drop to ~65 after MA)
    CH: 800
    CYA: 75
    Salt: 5400
    Borates: 50
    Temp: 70
    CSI: .17 (should drop to -.32 after MA)
    What do the experts recommend?
    BT
    15k Pebble Tec (2002), Ecomatic ESC-16 SWG
    Pentair Clean & Clear Plus Cartridge Filter Model CC420P (150GPM/420sqft/50psi)
    Pentair WhisperFlo Pumps x3, AO Smith 1 HP single-speed motors x3,
    Paramount IFCS, Taylor K-2006 Test Kit w/SpeedStir.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: To Drain & Fill or go Another Season
    If you can do it without incurring penalties, do it. Above 800 CH you don't get a lot of wiggle room to keep CSI in the safe zone. I was really hoping this El Nino year would pan out so I could drain my pool.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I ran a full season with the pool over 1000 CH, so it can be done. With a SWG you are going to have to keep a low TA and regulate the pH very carefully to keep the CSI near zero or very slightly negative. Once my CH got above 1200 it felt like walking a tightrope.
    chiefwej
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    You guys are all masterful CH tightrope walkers. Impressive!
    Jun 2014
    Chandler/AZ
    51
    Thanks guys, this is exactly the kind of info I need. Going to refill.
    Apr 2016
    Phoenix, AZ
    22
    To piggyback on this - what causes BassTrix's CH to jump about 300ppm/year? I live in the same area and refilled my pool water with fill water that reads 175 ppm CH. How can you avoid this number getting out of hand?
    Phoenix, AZ | 30,000 Gallon Pebble-tec pool + attached spa | Hayward cartridge filter | Pentair Intelliflo Variable Speed Pump | In-ground pop-outs | Taylor K-2006 Test Kit
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Quote Originally Posted by SunDevil1 View Post
    The high rate of evaporation causes the CH rise. The water goes away but the calcium is left behind. Keeping a pool covered would help, but other than that, it's just one of the joys of living in a desert.
    chiefwej
    Apr 2016
    Phoenix, AZ
    22
    Quote Originally Posted by chiefwej View Post
    Ahhhh that makes a lot of sense. I was worried about my CH being lower than recommended levels, but it looks like there's nowhere for it to go but up!
