Thread: Pool filter PSI drop after sand change/ plumbing repair?
    Jun 2015
    Sherwood, AR
    13
    May be a dumb question... But i'm an electrician not a plumber haha.
    A couple days ago I changed my sand and re plumbed around my pool pump/ filter. My old filter PSI after a good backwash was around 19. I also had a few minor leaks. Now there are virtually no leaks aside from the pump strainer basket when i shut off the pump. (i need a new gasket i know) Now my filter is sitting at a steady 10 PSI. Normal? My theory is just now with no leaks and fresh sand there isn't as much PSI? Im not sure.
    Any input? Thanks everyone!
    (hayward S244t filter/ 1 HP hayward pump)
    25,000 Gallon
    In-Ground Vinyl
    30,432
    Re: Pool filter PSI drop after sand change/ plumbing repair?
    Your old sand was pretty gunked up. You have less psi but a lot more flow. To prevent the new sand from becoming clogged just like the old, it's probably a matter of balancing your chemistry better so you don't have as much debris entering your filter.
    Jun 2015
    Sherwood, AR
    13
    Yeah that makes sense. Last year I tried the bleach method and struggled to fight algae the whole summer. And plus i had no idea when the last time the sand was changed. After i changed it the other day it immediately started clearing up within 24 hours.
    I was just curious if 10 PSI seemed normal.
    25,000 Gallon
    In-Ground Vinyl
    Jun 2015
    Sherwood, AR
    13
    Now it's dropped to 8 PSI?! that seems awfully low?
    last night i did her a strange humming from the pump so i went outside and no water was flowing... so i shut it off for the night. this morning i pulled a twig out of the impeller area and a few pebbles out from under the strainer on the pump..
    Did I burn it up?
    25,000 Gallon
    In-Ground Vinyl
