Results 1 to 9 of 9
Thread: Oil slick in pool after having used Magic Lube on O-ring for Polaris quick disconnect
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    Hi TFPers,
    I recently put some Magic Lube on the O-ring of the quick disconnect for my Polaris 280 hose (part #44 in Polaris 280 Hose Parts; Polaris 280 Pool Cleaner Exploded Parts Diagram
    I did this to make it easier to connect/disconnect the hose from the universal wall fitting. After I did this, I saw a small oil slick on the pool water. Yesterday, I disconnected/reconnected it and again saw a small oil slick. Was this okay to use Magic Lube on this part? Did I contaminate the water? The Magic Lube says it is waterproof, non-toxic, environmentally safe, so I assumed it would be okay. Thanks for any help.
    B
    19k gal IG plaster, built '70s, probably resurfaced in '80s-'90s; Blue Haven Hayward filter C4520BHMB (Filbur FC-1275 cartridges); Hayward MaxFlo sp2302 VSP 1.5hp; 6 solar panels 288. sq. ft. total (142"x47.5" ea.) on 1 story hm; Pentair Compool LX220 Solar Controller; FlowVis flow meter; Maytronics Dolphin S200; AG 300 gal AquaTerra spa; TF-100 & Speedstir; gone: Pentair Challenger 3/4 HP 1 speed; Polaris 280
    Jun 2014
    Rogers, AR
    428
    Re: Oil slick in pool after having used Magic Lube on O-ring for Polaris quick discon
    I use Magic Lube all the time. A Skum bug in the skimmer is the bomb though. My daughter put a combo of olive and coconut oil in her hair and I came home from work one day and my pool had a really bad oil slick. I popped my Skum bug in and it was gone by the next day.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    Didn't know there was such a thing. So, are you saying then that it was okay to use Magic Lube on that part that was/is exposed/submerged in pool water?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Shouldn't hurt anything as its water based.
    interesting item that scum bug, just added to amazon wish list.
    might come in handy some day.
    Dolphin E10 Cleaning Robot.
    Jun 2014
    Rogers, AR
    428
    Quote Originally Posted by borjis View Post
    I buy a fresh one every year. Your supposed to leave them in the skimmer all the time but I don't think it is necessary for us. I learned about them on this board and I really like them.
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    Thanks for the replies. And, I too added that Scumbug to my Amazon wish list. Never new about it either.
    The Magic Lube has made it a little easier to connect/disconnect my Polaris Quick Connect at the wall.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I've used the scum balls in my hot tub skimmer. Good for trapping the lotions and oils a bit... and don't look as creepy!
    Also, when lubricating o-rings in general, you don't need to over due it. A very thin coat is all you're looking for. Whenever I do it, I take the o-ring off of it's fitting the wipe it with a paper towel or cloth towel. Then I put on nitrile or latex gloves and put a small dab (pea size or less) on one finger tip. Touch the dab to a few spots on the o-ring then work the o-ring around the whole diameter with my fingers to spread the lube evenly. The o-ring should be glossy but no visible globs or streaks of lubricant.
    Isolated Spa - 345 Gallons
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    Ok Joel. Tx. Glossy, well after I lubed the o-ring in the quick connect had some it had some definite residual lube. Now I see and hear a little goes a long way ��
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    Tx again Joel.
    Yesterday, I cleaned my pool filters. I followed your steps to lube the o-ring for my filter housing drain plug, large gasket under the filter housing lid, and also my strainer cover lid. Worked quite well, and only used a small amount. I was not able to remove the o-ring from my strainer cover lid though on my Hayward MaxFlo SP2302 VSP. So, I just used a few small dabs and worked it around the o-ring with it in place. I guess I could have pryed it out with a screwdriver or something, but I didn't want to risk damaging it or the basket lid.
