Thread: Green Monster in CA!
    ok so here are the readings and my method
    20K gallon IG with pool cover
    CL 0
    PH - 7.3
    CALC - 290
    ALK - 70
    CYA - 20
    I usually start the year by doing 1.5 gallons of muriatic and after 3 hrs start hammering with 4 gallons of liquid bleach ....my problem is the bleach usually gets eaten immediately because CYA is low ....usually I have 0 CYA at beginning of year so is it ok to add bleach with 20 CYA or wait .....thanks!
    20k Gallon IG Plaster/Pebble Sheen Pool/ Cartridge Filter / Solar Panels
    Jun 2014
    15,103
    Re: Green Monster in CA!
    Since your water is green, and you need to SLAM (link below), you can add stabilizer now for a target of 30 and adjust/increase your FC to a SLAM/Shock level of 12 as listed on the Chlorine/CYA Chart in my sig link below. Your pH is fine for now, so I would not add any acid at this time. Everything else looks good. You also have the option of leaving CYA at 20 and using a SLAM/Shock FC level of 10 (little less bleach), but if you get a lot of sun, a CYA of 30 may be better for now. Either way, no waiting. SLAM-away!
    how can I keep the CYA climbing a bit as I SLAM? Are pucks going to do it or not enough and buy a 4llb stabilizer Thanks so much!
    Jun 2014
    15,103
    If I were you, I'd just pick-up a small bottle of stabilizer and raise it quicker. While pucks do work, they are slow-dissolving and could take a while. But you can use them later when you are ready (after the SLAM) to raise your CYA higher for the summer.
    got it thanks!
    30,419
    Never a good idea to use pucks during a SLAM. The SLAM does best on a quick, massive dose of chlorine (as in liquid chlorine) and is not intended to be used in conjunction with slow release pucks.
