Thread: Plumbing above ground pool
    Apr 2016
    Baton Rouge/LA
    3
    Some friends gave me an AGP. I have set it up and the pump (intex sand/chlorine generator) is running on an extension cord (I know big no no). My nearest outlet is about 35 feet away. I know most would say to dig a trench and run an outlet to the pool. I would rather put the pump near the outlet and plumb the pump intake and return lines through the ground with PVC. Is this too long of a run to do this? Am I putting undue strain on my pump by doing this?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Plumbing above ground pool
    Welcome to TFP!
    No, 35' of horizontal PVC run is not too much. I would use 2"
    Apr 2016
    Baton Rouge/LA
    3
    Thanks for the info and the warm welcome! I will follow your advice with the 2" pipe as well. Beautiful pool you have built there in your signature!
    DFW, TX
    24,450
    Thanks! When yours is up and running you know what you need to do! We like pics! Edit Signature
