Thread: Pool Draining Question
    Jul 2015
    Pflugerville, TX
    8
    We drained a couple of inches of water in advance of the storms this week. I ran a hose to the cleanout in the front yard near the sidewalk (City says to drain to sanitary sewer).
    I noticed there is another cleanout just a few feet away from the foundation also in the front yard.
    I'm assuming they're both connected (you can hear water running as I was running the pump) and that one is the "city" cleanout and the other is my "residential" cleanout. Not sure of the proper terms....
    Is there a difference as to which one I drain to? We picked the city one because it was further away and less apt to get water backing up into the house.
    Thanks!
    16K gal, IG, Plaster/Pebble (WetEdge), Quad DE 80 Filter, 3 HP IntelliFlo VS pump, MasterTemp 250k, booster pump, Racer
    Freeform, water sheer, tanning shelf, bubbler. Completed Oct 2015. TF-100 Test kit
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,580
    Re: Pool Draining Question
    I think a picture or two will help us answer your question better.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Yes, either is Ok, the one farther from the house is what I would use too.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,048
    My kitchen sink cleanout is on the back of the house. Once I set the submersible pump to flush that line out. I had to throttle it back by crimping the hose with visegrips, but after a thousand gallons or so, I was able to open it up and let 'er rip. Whatever buildup was in that long run of sewer pipe certainly got flushed away!
    Jul 2015
    Pflugerville, TX
    8
    This is an old picture from construction. My backwash hose only reaches the sidewalk cleanout with a foot or two to spare, which when pumping tends to lift out of the pipe (even on 800 rpm or so). The nearer pipe would be a bit more convenient so it's good to know I could use either if the need arises.
    Thanks!
