Results 1 to 7 of 7
Thread: Run pool and spa on one pump?
    Sep 2008
    Toronto, Ontario, Canada
    52
    While researching variable speed pump options, I'm reading a lot about sizing the pump with spa and pool in mind. My pool, built about a decade ago has a separate pump for the spa outlets. It kicks in when I turn the spa on but otherwise sits idle.
    Now that VSPs are common, is it standard pool design to have both the spa and pool on the single pump and to have the pump switch to high rpms for spa mode? Is this the reason to go with more powerful 3hp pumps?
    Concrete (gunite) inground pool and spa (17,000 gallons)
    Hayward H350 natural gas heater (electronic)
    Goldline Aquarite chlorine generator
    Hayward pumps, Hayward Pro Series sand filter, Goldline valve actuators
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Run pool and spa on one pump?
    My spa and pool share the same filter pump and heater. There are three way valves where the two lines T together. There's also a separate spa pump that just recirculates the spa water, but it doesn't heat or filter it. It has its own drain and returns. never use it -- too much aeration cools the water off really fast.
    Sep 2008
    52
    My filter pump recirculates the water through the spa and pool. It's just when I turn on the spa "mode" that the dedicated spa pump turns on giving me a more powerful jet in the spa. It does go through the heater.
    I was just wondering if that was the normal setup now that variable speed pumps are commonly available. I've never had occasion to work with any pool other than my own.
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    My pool is exactly like this minus the extra spa pump that nobody ever really uses but has to maintain. I have one variable speed pump that handles everything.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    Sep 2008
    52
    Quote Originally Posted by robdac View Post
    What's the diameter of your lines and what VSP do you have? Just wondering if I can manage this with 1.5" lines.
    Dec 2015
    Converse
    17
    Your looking for a smaller vsp for your application. I recommend pentair superflo vsp, which can produce up to 1.5 hp. I would run your pool on a very low speed for a long period of time. Lower the speed and longer the run time equals savings on electricity. Then kick it up to high for spa mode. With 1.5" plumbing anything bigger would be a waste.
    Sep 2008
    52
    Quote Originally Posted by Chncdafied View Post
    Sent from my SM-N900T using Tapatalk
    Thanks for that. I've sized down to a AO Smith/Century ECM16CU variable speed motor. I will just replace the motor since the pump is only 4 years old and in good shape. Also, that means I don't have to mess with plumbing. I plan to document my job and post back my results.
