Results 1 to 7 of 7
Thread: pool opening a green swamp
    May 2014
    Muncie, Indiana
    30
    Hello there... opened up my pool on Sunday and it was a green swamp. Added banish and spot killnand it created a foamy film on topnof the water. I know its from the algecide. After three days not much improvement.
    My readings are:
    ph 7.2
    fc 9
    cc 1
    tc 10
    calcium 250
    ta 90
    cya 80
    question how much liquid chlorine should i use to get to shock level such as in the slam process?
    12k gallon inground pool with vinyl liner. Sandfilter, hayward 1.5 hp pool pump. Pool is approx 15 yrs.old. Liner is four years old. TF100 testing kit.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,428
    Re: pool opening a green swamp
    http://www.troublefreepool.com/calc.html
    You will LOVE this! It does all of the work for you!
    What are you testing with? Can you add it to your siggy please?
    Kim
    May 2014
    Muncie, Indiana
    30
    Tf 100 kit
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Silly question but what is "banish and spot kill" and why did you put them in there? Knowing that might, help folks guide you better.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    May 2014
    Muncie, Indiana
    30
    They are algaecide and chlorine to help open the pool up
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Okay. All we recommend is bleach or liquid chlorine so I had to ask. According the table, with a CYA of 80 you are going to have to raise FC to 31.
    Oh Oh! I just checked and Banish is listed as copper based. Hopefully you don't end up with staining from that. But if you do we can get you fixed up.
    May 2014
    Muncie, Indiana
    30
    Thanks! I just didn't want to under or over chlorinate it
