Results 1 to 7 of 7
Thread: Keeping pool cool..
    Apr 2016
    Kershaw, South Carolina
    80
    Keeping pool cool..
    Hope this is the place for this.. closest I could find.
    I see a lot of stuff here about pool heaters, what about keeping the pool cool? We have a white fiberglass pool installed last spring, got the white on the advice from our installer so as to keep the pool cooler in the summer. BUT.. sometimes in the heat of the summer here in SC the pool feels like a hot tub..well a warm tub anyway. So last year I changed from running my filter during the day, to at night. I leave the slide on so the water flowing down it is somewhat cooled by the night air. Any other ideas on keeping these things cooler in the hot months?
    Pool... IG 16,500 gal fiberglass, Pentair Sand Dollar filter, Pentair Superflow 1 speed pump, Pentair control box, Installed 4/2015, Test strips! HA! ;-), SWG, hot tub (spa) freestanding on deck, fill it from my well, sometimes through my water softener. Oh, and a HydroNet radio control leaf skimmer boat! AND... A brand spankin new Dolphin M500 robot! ;-)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Keeping pool cool..
    Screw in an aerator into a return jet and run some at night. Just be advised this will raise your PH so keep an eye on it. You can buy or make one for 20 to 30 bucks.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,504
    Here is one, Skippy's New Fountain
    Apr 2016
    80
    Interesting, I have screw in "eyeball" jets that I can change flow direction with, I'll have to take one out and see what I can come up with I guess. Thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by A.O. View Post
    I discovered quite happily that a " PVC fitting is a snug friction fit inside my eyeballs. Once I jam a fitting in to give me a starting place, there's no limit to what I can create using PVC pipe.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Can't help myself. "" PVC fitting is a snug friction fit inside my eyeballs" That sounds painful!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    I have one of these and it works very well for cooling the pool. Just make sure if you adjust it to spray really high if you get strong winds where you live the wind can push the water while in the air out the pool. Does that make since?
    Basically at night when im not outside around the pool to watch I adjust it so the stream is very high.
    Wayne
    24'X54" Round 15,000 Gallon Pool
    Pentair SD-60 Sand Filter With 1.5HP Pump & Center Floor Drain
    Lil' Shark Vacuum With Leaf Canister
    New TFPC User And Couldn't Be Happier
    Pool School + Test Kit + Pool Math = A Perfect Trouble Free Pool
