Thread: Stamped concrete sealer recommendation?
    Jun 2013
    Southeast Pennsylvania
    124
    Hi,
    I have a stamped concrete pool deck. It will be its third season here in Pennsylvania. I need to seal it this year. What ever is on there now from the builder gets slippery when wet. So, I'm first looking for a good product and hopefully is not slippery when wet.
    Doug
    13,500 Gallon Gunite Aggregate Finish, DE, SWG, 2.0 HP pump, 1.0 HP pump for 3 Sheer Descents
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Stamped concrete sealer recommendation?
    Hey Doug, sorry we missed your post, there are many different sealants out there, here is one I was looking at for the future.. you can add non slip into it..
    EnduraSeal 100% Acrylic Semi Gloss Concrete Sealer Solvent Base - 5 Gallon - Household Paint Solvents - Amazon.com
    Amazon.com: BonWay 32-541 Gator Grip Slip Resistant Additive for 5 Gallons: Home Improvement
    Hope this helps
