Thread: Plaster Discoloration and rough surfaces on 2 yr old pool Need advice!
    Apr 2014
    New Orleans
    6
    Hello all,
    I need some assistance. My Pool is about two years old to the date. I have a quartz plaster saltwater pool and I have some discoloration in the plaster and some of the surfaces are very rough. They have been there since the pool was installed, but I thought at first that they would go away, but they have not. The more I read on here the more aggravated I get about them. What are my options to get it fixed. Attached are some photos. I am working on getting my chemistry up to par right now. My numbers are as follows: TC=4.5, CH=450 ppm, TA=70 and CYA= 23. I know my numbers are a bit off, but hope to have them under control shortly..
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: Plaster Discoloration and rough surfaces on 2 yr old pool Need advice!
    What color is your plaster?
    How did you get a CYA of 23? The typical tests are not nearly that precise.
    Plaster discolorations are cause by scale (your current numbers don't indicate this), poor workmanship (calcium chloride added to the plaster mix or excessive water), and organic color pigments ( yours looks blue to me and blue is by far the most susceptible) that are prone to losing color from exposure to chlorine.
    There are other reasons for discoloration, but those are the most common.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Have a look at this, Diagnosing Pool Plaster Problems
    Apr 2014
    New Orleans
    6
    If I remember correctly, they put the hose in it when they were walking out. The plaster is a light grey with quartz mixed in it.
    Dec 2015
    Converse
    17
    Electrolisis, do you have an anode on your pool equipment
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    Quote Originally Posted by Chncdafied View Post
    Sent from my SM-N900T using Tapatalk
    Could you give a little more details what you thing is going on and the whys of it please.
    Kim
