Results 1 to 18 of 18
Thread: So confused, which SWG???
    Jul 2014
    Hudson, wi
    81
    I want to switch to a SWG but there seem to be so many options where do I start.?.? I'm in the upper Midwest with a 3-4 month pool season, will the cell last longer with the reduced use? What have people had the best luck with? Thanks for the help.
    21,000 gallon IG with vinyl liner, Pentair sand filter, TF100 test kit, pool is about 15 years old.
    new in 2016 - Hayward SWCG with T15 cell
    Jul 2015
    Central Valley CA
    1,109
    Re: So confused, which SWG???
    The Cell will last longer the less it is used, the expected life of a cell is based on generating x amount of chlorine for x amount of hours. That is one of the reasons people suggest getting a cell larger than you need, the incremental cost of a larger system is usually low compared to having to replace the cell sooner. The other reason to go big is to reduce the amount of time you have to run your pump to generate enough chlorine. Sorry no suggestions on brand but from what I have read hard to go wrong if you stick with the major equipment manufacturers.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    I've been happy with my Aqua Rite (Hayward) that I've had since March 2004.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Yes, that seems to be the fan favorite at TFP.
    Jul 2014
    Hudson, wi
    81
    DFW, TX
    24,514
    Yes, that is the ticket!
    That and this page will get you going, Pool School - Water Balance for SWGs
    Jun 2015
    Rocklin Ca
    78
    I have the Aqua Rite The first year the cell went out,they did give me a replacement, second year The circuit board went bad they did replace it. the rep said he's never heard of one going bad . then when it broke again I gave out I call it my $1000 thermometer. . Now I just keep the salt level at 2800 to 3100 and just use liquid chlorine. But I would like to replace it, the little time it worked it was nice. I have been looking at these Circupool Amazon has some good reviews, but I did read some that just slammed it especially customer support if you have a problem . Bottom line I'm confused also
    BTW last was the first full year of using/following TFP my pool looked so good.
    In ground 20,000gal - pebble-tec - salt, Intelliflo pump, Sta-Rite filter 450 sq ft ,Hayward 6060 booster pump, non functioning Aqua Rite SWCG, TF 100 test kit.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I've had an AquaRite AQR15 for 11 years now. I love it. In fact if the whole system died today, I'd buy another tomorrow. My first cell lasted well over 7 years, and cost $400 to replace. That makes my chlorine cost less than $57 per year, and that's for a 19,000 gallon pool that's open year-round in very sunny Tucson!
    The input resistor on the main circuit board did fail at about nine years, (which is a common problem on the earlier units), but a $2.50 part and 15 minutes with a soldering iron put it right back in service. I like many others here recommend the AQR15 as a solid choice for a SWG.
    Oh another advantage is, unlike several other brands, you can adjust the output in one percent increments without the need to be controlled through an automation system.
    chiefwej
    Jun 2015
    Rocklin Ca
    78
    The Varistor also went out on mine I did replace it no help. I've also thought about buying a new Circuit board and cell.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Quote Originally Posted by SacDave View Post
    If you want to get the AquaRite back in service, you should start your own thread on that topic. I'm sure there are poeple here who can help you do that. The most expensive part of the whole system is the cell, and if a controller failure is what put the system out of service, it's possible that there may be some life left in the cell.
    chiefwej
    Apr 2016
    FL
    7
    In the same boat so which did you go with? Everybody is on the Haward bandwagon it seems but I'm not sold yet. Comparing is very confusing.
    I have a 6 year old 15000 gal unscreened Salt pool in Central, FL. It runs on a 3/4 HP pump and the original equipment is Zodiac/Jandy/Aquapure 1400. I am looking for a new system to replace the Jandy. My current system is Jandy/Aquapure 1400. Looking at a dead cell/power chord/sensor issues now so not worth fixing I guess. Looking at Haward, Circu-CompuPool, Pentair, but open to anything. Thanks!
    Jun 2011
    Long Beach, CA
    2,790
    Quote Originally Posted by TWM View Post
    Going by what you said you need, your cheapest option is staying with Jandy and replace the cell, power cord, and get the newest style of sensor.
    Is there some other reason you are researching on switching brands?
    If you need more information, I suggest starting your own thread.
    Nov 2010
    DFW
    29
    I have a Pentair IC40 which I suspect died a year ago+ despite all green lights. I've replaced the flow switch 3 times which at $75 a pop kept me limping along but even tho I was set at 100% output, I was still pouring in bleach. Again this year cell is off (red) indicating low salt (not the problem), low temp (not the problem), bad flow switch (maybe), bad cell (most likely). Highly recommend avoiding the IC SWGs. Short warranty and short expectation of life at 3 years before you'll need to replace ($600 for cell alone). I'm debating between the Liquidator or new SWG even tho I'm loathed to spend another $G on a new setup. LQ can be had for $200 but I've read people are having problems with those. Stenner looks interesting but seems like an incredible amount of hassle. Interested in the AQR15 based on this thread, especially if the claimed longevity accurate!
    18,000gal IG with FG finish + spa, Pentair CCP 420 filter, Pentair VS pump, Hayward AQR15 SWCG, Polaris 360, 325k BTU heater...
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I just bought mine so I'll let you know, but the reason I chose the aquarite in addition to the happy TFPers was because all the guys at the company that built my pool have that brand, they report getting up to 10 years out of the cell...and the fact that they all own them also means they're good at fixing them, but likely don't have to very often
    Kinda like "what kind of car does the mechanic drive."
    Ps...yes Virginia, there really ARE PBs who like swg
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Apr 2016
    FL
    7
    500 for the cell, 60 for the power chord, getting some bad reading on the back board too so that might be next...
    Anybody tried the Autopilot Nano 28,000?
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Thanks for this post, I'm about to pull the trigger on the Aqua Rite after fighting with this compupool junk over the past several years. They can't make a product that last more than 2 seasons.
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
    Apr 2015
    Central FL
    46
    I have an autopilot nana 28k and like it a lot
    10k gallon IG pool. plaster/pebble. pentair clean & clear cartridge filter. Sta-rite max e pro model p6ra6e-205l pump. autopilot nano plus SWG
    Nov 2010
    DFW
    29
    I pulled the trigger on the AQR15 and installed today. Only minor hurdle was accounting for the additional space the external flow switch requires. Not a difficult install if you're already plumbed for a SWG. Such an upgrade over the Pentair garbage already with the control box being able to read temp and salt levels. Only thing I don't like about this setup is that I can't check the status of the cell at a glance, I have to open the control box and check for green lights. We'll see how it goes. Ready to set the pool back to autopilot after 2 difficult years.
