Thread: Hole in wall problem
    I need help! I have an old 60x40 gunite pool that I manage. Several years ago it was converted to a liner pool. This was not successful because it has floated and the coping has moved. We are removing the liner and applying Permaflex. Once we removed the liner, we found the corner where the old concrete steps were removed and the hole filled with Pool Krete. Do you have any suggestions what we can fill that hole in with that will stick to Pool Krete in order for us to apply our permaflex and paint? Someone mentioned Fiberglass(Automotive kind) or concrete but they are not sure if it will adhere to Pool krete that stays damp.
    7,400 gal Oval AG
    Cartridge Filter
    1.5 hp Pentair filter
    Jul 2008
    Pittsburgh, PA
    118
    Re: Hole in wall problem
    I have never worked with that product but I do work with pool crete a lot and I dont think anything will stick to it. It expands and contracts too much. Luckily it is pretty easy to break up and remove.
    Matthew
    Involved in the pool and spa industry
    Pittsburgh, PA
