Results 1 to 11 of 11
Thread: "No Flow Filter Pump" Still On After Installing New Cell
    Apr 2016
    PEACHTREE CITY/GA
    6
    Just replaced my T-15 chlorinator cell. Had some problems getting it to work but after re-soldering the back of the K-1, the chlorinator appears to be working fine. But I still have another problem. When I turn on the filter pump, it runs for about 15-20 minutes then shuts down and I get a "No Flow Filter Pump" message. If I try to turn it back on it immediately comes on, then 15-20 minutes later shuts down again with the same message. Got the same message for the first time about a week ago along with "Low Volts," which is why I replaced the cell. It seems I've fixed one problem but not the other. Last week when I first got the two messages I backflushed hoping that would help, but it did not. Water pressure appears normal. Not sure what to do next. Any suggestions? Thanks.
    2005 IG 15,000 gal, gunnite, Pentair DE filter
    Hayward Goldline Aqua Logic SWG
    38,237
    Re: "No Flow Filter Pump" Still On After Installing New Cell
    Welcome to TFP!!!
    The flow switch is not in the cell. It is a separate switch in a PVC tee.
    Do you have enough water flow?
    Apr 2016
    PEACHTREE CITY/GA
    6
    As far as I can tell yes, water flow is good, but how can you tell for sure? I'm familiar with the location of the flow switch. It appears to be working normally, i.e. I only get a no flow message when the filter pump stops running. And as soon as i restart the filter pump, the no flow message immediately goes away.
    Apr 2016
    PEACHTREE CITY/GA
    6
    Can a faulty flow switch cause the filter pump to shut down? While I'm at it, what are all the things that can cause a filter pump to shut down (assuming the pump itself is fine)? Is there thermal protection, no pressure protection, etc? I have no idea.
    38,237
    Is the pump turning off or the SWG?
    Nothing should cause the pump to turn off except if you have automation with a safety feature enabled.
    Apr 2016
    PEACHTREE CITY/GA
    6
    The pump is turning off, and I have no idea why.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Pumps have internal thermal protection that will shut them off if they get hot.
    38,237
    Right, I missed the point about thermal protection.
    Apr 2016
    PEACHTREE CITY/GA
    6
    I figured it probably had thermal protection. So far today it's running normal. I will return to this thread if the filter pump has another uncommanded shut down. I appreciate your help.
    Apr 2016
    PEACHTREE CITY/GA
    6
    OK, it happened again today. After running for about 15 minutes, the filter pump shut off on its own for no apparent reason, along with a message,"Check system, No flow-filter Pump". I turned it back on and again it ran for about 15 minutes, then shut down on its own with the same message. It ran perfectly yesterday, so I have no idea what's causing this. Any ideas?
    Jun 2011
    Long Beach, CA
    2,778
    This is a pump issue, not a SWG issue. Please list all of your pool equipment in your signature as that will start to give us a clue as to what we are trying to troubleshoot.
