Results 1 to 10 of 10
Thread: I want a new pump, I want one that does what it should...
    Apr 2016
    Grimsby Ontario
    22
    I would really like to replace the pool pump, but if I need to repair a line that will need to come first ----
    IMG 56941 - YouTube - video of the pump working with it set to filtering
    IMG 56951 - YouTube - video of the pump set to recirculating
    first of the season last year it was working fine- then part way thru the nieghbor said it has been the loudest he has ever heard it... and it kept losing prime as well - I was hoping to get thru last summer and pick up a pump this season....
    the url attachement thing was not working for me
    Tim
    ____________________________________________________________ ____________________________________________________________ ____________
    14 x 28 x 5 1/2 feet - 16000 gallons - IG (1960's concrete) Vinyl Liner, Sand Filter (Sand Master SM2306T), 1 hp Purex Challenger? (Faded label), Municipal Water.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Re: I want a new pump, I want one that does what it should...
    One that won't make my pool look too bad...
    One that will circulate real good...
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Nice tunes!
    Are you interested in a variable speed pump? Here is a nice pump that should work nicely for your pool and save some money on electricity. Pentair SuperFlo VS Pump 342001 | Pentair 342001
    Apr 2016
    Grimsby Ontario
    22
    I was having a hard time finding that model here in Canada- it was the older model that I could find. I think my plan of action is going to be to cut everything out, build a proper pad and hope that new pipes and pump will solve my air issue...
    Tim
    mas985's Avatar
    Pleasanton, CA
    11,742
    You have a serious air leak in your system. If you fix that, it could help with the noise.
    Have you tried lubing the pump lid gasket?
    Have you made sure that the skimmer is not sucking in air?
    Have you checked all connections to the pump to make sure they are tight and not leaking air?
    Once you fix the air leak and if the motor is still too loud, another option would be to just replace the pump motor. Failed bearings is usually what makes a motor loud.
    Mark
    Apr 2016
    Grimsby Ontario
    22
    I was going to cut out the pump and reconnect and give it the 8 of straight pump that it needs and put in a union fitting.... but in the end I need to build a new equipment pad. So I am going to cut everything out and build a pad this weekend.
    I am also going to pick up a new pump, i got a used Chlorine Generator from a guy a work, so most of what I got needs to change....
    Tim
    Feb 2016
    Near Toronto, Ontario
    48
    From my industrial experience (pumps ranging from 1 to 1000 HP), if you are cavitating your pump (drawing air) you're going to have serious issues - I have to second mas985, but not only that, boost the severity of what he is saying. Not only is air going to make pumping louder and make pressure unsteady, but over time, it will destroy the impeller in your pump (old or new).
    I wouldn't touch the pump until you have the air issue (suction side leak) settled - you may rapidly destroy the impeller in a new pump, and you really don't want to do that. Once the air issue is settled, you will see much better pressure regulation.
    ed
    Approx. 22,000 gallon 15 x 30 tile lined indoor pool, Taylor K-2006, heat exchanger from main boiler, 3/4 hp Hayward Super Pump, SandMaster sand filter.
    May 2013
    Long Island NY
    419
    Yea you have an air leak somewhere, you shouldn't see all the bubbles through the lid like that.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Apr 2016
    Grimsby Ontario
    22
    I have bought a new pump Hayward 5206 variable speed- have cut out everything from the suction to the return by the pool equipment pad- adding in a Saltwater generator- go big or go home...
    Tim
    Aug 2010
    Dallas, TX
    4,052
    Whoa! I've never seen one leaking that bad!
