Thread: Another pump not starting
    Feb 2014
    Houston, TX
    161
    so about a week ago i noticed my pump would occasionally make a noise before starting up. If i turned it off and on i wouldnt reproduce it. I figured the bearings were going bad.
    Today my pump would not turn on manually. I checked the capacitor even though it wasnt humming. It seems my pump isnt getting power but if i turn the timer enough times i can get it to turn on once.
    Do timers stop working like this or is it likely my pump?
    Feb 2014
    Houston, TX
    161
    Re: Another pump not starting
    Btw the pump timers gears are turning. I also have another timer for a booster pump going to the same breakers and it works perfectly fine. Turn on and off always when tripped manually
    Dec 2015
    Converse
    17
    Could be welded points on your time clock. Your gonna need someone to check voltage from the time clock to the motor and at the motor. If no voltage at timeclock, bad time clock. If voltage to motor, bad motor. If capacitor had been changed, time for a new one.
