Results 1 to 7 of 7
Thread: Should I plumb back wash pipe
    Oct 2008
    San Jose, Ca
    38
    Hi,
    Now that I got some of my previous problems solved with the help of this forum, I'm looking to connect the backwash output of my filter to a drain. It currently dumps all the back wash onto the concrete pad that all the pool equipment sits on. The question I have is should I also route the filter's plug to the drain. For example, lead the backwash pipe to the back of the filter where the plug is. Add a basket/gutter of some sort so when I remove the plug, the waste can drop straight in. Then continue the connection to my sewer drain. Here's a pic of my current setup, which I inherited.
    ftp://cadenlc.net/Push%20Pull%20Valve.jpg
    Needless to say, it gets very wet, messy and dangerous when I backwash or clean out the filter.
    Thx.
    -Rich
    20k Gallon IG, Hayward 1.15HP RS750 Pump, Purex Triton Nautilus FNS 48 DE Filter, Polaris 280 w/ PB4-60 Booster Pump.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Should I plumb back wash pipe
    Link doesn't work.
    Oct 2008
    San Jose, Ca
    38
    Worked for me, but here's another site.
    http://www.linzarni.net/pool/Push%20Pull%20Valve.jpg
    Oct 2008
    San Jose, Ca
    38
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    The ftp site asks for a userid and password when I try to view those pictures.
    I'd highly recommend plumbing the backwash line. It's a good idea to add a sight glass to the line so you can see when you are done and also so you'll notice if there is flow there when there isn't supposed to be.
    Plumbing a drain for the filter drain would be nice, but it's hard to say if it would be worth it. My equipment is indoors, and I put a drain in the floor near the filter. I only drain the filter once a year, so I can deal with a little water then.
    Oct 2008
    San Jose, Ca
    38
    Try this link.
    http://cadenlc.net/pool/Messy%20Pool%20Center.jpg
    http://cadenlc.net/pool/Filter%20Bac...h%20Outlet.jpg
    http://cadenlc.net/pool/Filter%20Bac...Outlet%202.jpg
    I'll keep in mind the sight glass. Right now, I was planning on connecting a flexible hose from the back wash line going to the back of the filter then out to my drain. Hope the picture makes more sense. I've had to drain my filter about 5 times in the last 8 months due to various reasons.
    no-mas's Avatar
    Jun 2008
    FL
    405
    At a minimum, get a backwash hose so all the backwash water isn't at your feet, but plumbing it to a drain is better still. My filter drain plug is not plumbed to a drain - I only empty it a couple of times a year max, and can deal with a filter tank full of water. I couldn't backwash right at my feet, though...
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
