Thread: Help.. Over my head and Confused
    Apr 2016
    Johnsonville, SC
    2
    This is my first post, so I apologize for the rookie/noob questions. I hope this is posted in the correct place and I am sure it's been discussed before, but I need help.
    I have a Intel 18x48 pool that I am upgrading the pump/filter to a 2800gph sand filter setup with a Hayward thru the wall skimmer. I have no idea what fittings to use in order to connect the skimmer to the pump.
    I have looked at pictures but I am confused. Can somebody help me with the parts/fittings that I need to connect the skimmer to the pump. I would like to add an on-off valve to this line.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Help.. Over my head and Confused
    You'll probably find what you're after in one of the threads referenced in Useful links for fellow Intex Pool Owners
    PS Welcome!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    HI! We also have a whole, wonderful section for Above ground pools you can post in if Richard's thread does not help you.
    Kim
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,528
    Here's how I did it. My Hayward came with a graduated adapter that screws into the bottom of it. If you don't have one, it should be pretty easy to find online.
    Notice I had to move the valve to the other end of the hose, right before the pump. Works just fine!
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
