Thread: Replacing cracked eyeball return
    Apr 2016
    South East USA
    78
    Hi,
    Pool was built around 2005.
    I have an eyeball return on moulded step/seat in the deep end.
    The return is pretty shallow (maybe 12 inches under surface) so I guess it has seen a lot of sun.
    The eyeball part has popped off and the bezel is cracked. There is also a receiver part that is screwed into the pipe, but the receiver and its threads seem fine..
    Should I replace the receiver or just the eyeball and the bezel? It seems like a bother to get the receiver out.
    Also, there are several other similar returns that are lower in the pool and do not see as much sunlight. They appear to be in good shape. Should I do any preventative maintenance.replacement on these or just wait for them to fail in due course?
    Many thanks,
    ft.
    ~22,000 gallons, freeform, Pebbletec, beach entry AquaRite SWCG v1.33 Hayward Tristar SP325EE pump for main draw & skimmer Hayward sand filter S310S 1.5 hp booster pump Paramount PCC2000 in-floor cleaner, skimmer, debris containment canister Waterfall Pentair Intellibrite 5g LED light in Pentair stainless wet niche Jandy Lite2 heater: removed Auto-fill: deactivated
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Replacing cracked eyeball return
    I would just replace the failed eyeball and bezel. Here are a whole bunch, Wall, Return and Eyeball Fittings.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I'd go for just the eyeball and bezel.
    Solar Blanket, Well Water, Borax Added. 68
    Apr 2016
    South East USA
    78
    OK, many thanks. Will just do eyeball and bezel.
    ft.
