Results 1 to 14 of 14
Thread: Is bottom drain needed?
    Apr 2016
    Pittsburgh, PA
    5
    I am in the process of having my inground pool's liner replaced and the guy doing it asked if he can plug the drain in the bottom of the deep end. He said that they often leak and are tough to repair. I am hesitant to let him because I am assuming that if it wasn't needed it wouldn't have been installed in the first place. If the drain is plugged the only feed to the pump would be the skimmer. The pool is approximately 40,000 gallons. Do I need to keep the drain?
    38,489
    Re: Is bottom drain needed?
    Many pools do not have them. They are not required.
    They might add slightly improved circulation and can be helpful for removing debris, but there are ways to counter these without the floor drain.
    Since you get freezing up there, I would be inclined to cap it off.
    Please add your pool details to your signature as described HERE as it will help us help you.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    In my experience, about all the drain is good for is minimizing temperature stratification. Even set to full drain, debris floats right past it when I brush.
    If I had a vinyl liner, I'd be very wary of having someone cut through the bottom of it.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I agree with Richard, I don't have one on my 20x40 pool, and the only issue I have is water temperature stratification (cold water sinks to the deep end), I have been able to mostly fix this problem with the addition of a venturi assisted return like this Infusion Pool Products - Save Time, Energy and Money with our new, easy to install Venturi Return Fitting. at the the deep end to better mix the deep water.
    Ike
    Apr 2016
    Pittsburgh, PA
    5
    Is there any chance that I will starve my pump by cutting it's inlet in half?
    38,489
    No.
    Although on a 40k pool, I would think you would have more than 1 skimmer. Use 2" pipe for the suction line(s) as a minimum.
    Apr 2016
    Pittsburgh, PA
    5
    The pool has one skimmer with a 1 1/2 line.
    38,489
    Well, that is going to limit the amount of water your pump can move, but it will not hurt the pump.
    Apr 2016
    Pittsburgh, PA
    5
    Thanks, I appreciate the help.
    40K gal, IG vinyl, Hayward Superflo pump with 1 1/2 HP AO Smith Variable Speed Motor , Hayward EC75 DE filter, , Dolphin Supreme M4 cleaning robot
    mas985's Avatar
    Pleasanton, CA
    11,741
    Mark
    Apr 2016
    Pittsburgh, PA
    5
    Thanks, that was very convincing.
    Jun 2015
    Hanson/MA
    33
    I think you might have a problem keeping that pump fed with water with only 1 skimmer. I have a 20X40 inground liner pool, it has no main drain but has two skimmers and two returns. The water drops about 1 inch in the skimmer basket from the pool with the pump running 1.5hp pump with DE filter and 1.5" lines. Anything more then 1 inch of water below the mid line of the skimmer trim and it will funnel the skimmer basket and get air. My pool had a 1 hp pump when I bought the house and I think that is probably better suited for the two skimmers if I had known that I would have probably not have got a 1.5 hp pump.
    Jun 2013
    South Florida
    118
    Quote Originally Posted by PunKid View Post
    Based on my experience, I agree. I have a 1.5HP pump, and I have to split flow between the skimmer and main drain. If it is set to skimmer only, it is quite easy to suck air if the pool water level is slightly low.
    I like having a main drain, it is easier to brush sand and dust to the main drain and let it suck it up.
    10,000 gallon in ground diamond brite, Circupool si30+, Hayward C900 cartridge, 1.5hp Flotec single speed pump
    Jun 2014
    Rogers, AR
    428
    I like having a main drain as well.
    The temperature stratification and when I brush I can see stuff being pulled into it.
    I pull from my main drain whenever I brush and I brush a lot.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
