Thread: Pool Cover for newbee
    May 2015
    Holland Patent, NY
    6
    Hello all. Last year we installed a new Radiant pool. We put a cover on it. We were told we didn't need to put a pillow in the middle. We have a lot of trees around us. Unfortunately we can't avoid the trees. Anyways, we ended up with a lot of leaves on top of the cover which appears to have made the cover sink down. What a mess we now have. We tried to pump out as much water as we can but it seemed like we were going to have to empty it.
    Next year, would you suggest a pillow or did we do something wrong? I'm thinking of a pillow AND a leaf cover. Lol. Any suggestions? Gotta start planning and getting better before next year comes.
    18' Radiant round x 52" above ground pool. Starbright SB-40 sand filter system with Dynamo 1-1/2 HP pump. Pump model #S48AB86A03R. All installed May 11, 2015. New pool owner since May 2015.
    Jun 2015
    Ottawa/Ontario
    340
    Re: Pool Cover for newbee
    You need to remove the leafs that accumulate on the cover as much as possible. I removed accumulated leaves at least three times before the snow came and everything froze. I also kept the water from building up too much, and pumped water off as much as I could up until it froze.
    After the snow melted, i removed the leaves again, and pumped all the water off the tarp. For pumping I used a 1/4 HP submersible pump with a screen and low water shut off. The pump also comes with its own GFI for extra protection. A standard hose attached to the pump outlet lets me pump far from the pool.
    As for a pillow - i am not familiar with what that is. I can tell you that the volume of leaves in my pool this year vs last year when we didn't have a cover was substantial.
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Many of the covers for AGP need pillows which keep water and debris from sinking in the middle. They push water and debris to the outside walls which makes clean up easier.
    As mentioned above, it is easier to pump off water and clear off debris throughout the winter as needed. Leaf nets can be helpful, but also do best when you clear it off through the season.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,543
    I used my solar cover instead of a pillow this past winter. It worked great, and I needed someplace to store it anyway.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
