Thread: How to open a sand filter
    Jun 2008
    North Carolina
    38
    I am getting ready to open the pool, but I am not sure how to open my sand filter in order to fill it and take a look at the sand. I have looked all over the forum and looked at my manual. It says to replace the sand open the filter and then gives other directions. Nothing about how to get the thing open. It is a waterways clearwater sand filter. There is a large black rubber ring between all the valves and the filter body. It says tighten and loosen on it. I turned it and took out the screw but was afraid to mess with it any more. Do I just take this ring off, lift out the top part with all of the valves and then I will be able to see inside? Thanks for the help!
    Round 24' AGP
    13,500 gallons of cold water
    Sand filter
    BBB
    North Carolina
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: How to open a sand filter
    Do you know what model the sand filter is?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I'd suggest leaving it alone unless you have problems with it. The sand will last for years, and doesn't need to be changed routinely. You'll usually have to open it to fix a problem eventually, and you probably will want new sand then.
    Jun 2008
    North Carolina
    38
    Got it! Thanks!
    Round 24' AGP
    Sand filter
    BBB
    North Carolina
