Results 1 to 8 of 8
Thread: Accidentally got some Simple Green in my pool...
    Apr 2015
    Charlotte, NC
    19
    Arrow Accidentally got some Simple Green in my pool...
    I was cleaning my deck and inadvertently got some Simple Green in my pool. Since it was already diluted and spread on the deck when it dripped in along the edge of the pool, I can't say how much actually got in there, but it was not much. My gun-to-the-head guess is at most a couple ounces. My pool is 10-12K gallons.. Should I worry about it, or do anything about it at this point?
    10,000-gallon inground pool, Jet Black PebbleTec / plaster
    Hayward S244S Sand Filter
    Hayward Super Pump, 2 HP
    Hayward AquaRite AQR9 / T-CELL-9 ECG
    Polaris 360
    JoyfulNoise's Avatar
    May 2015
    13,199
    Re: Accidentally got some Simple Green in my pool...
    You'll be fine. There's nothing in it that either won't be broken down by chlorine or is basically harmless.
    Matt
    Jun 2014
    15,091
    I've heard of much worst items and quantities getting into the pool. :Brickwall: Eventually it should just dilute and you'll never even know it was there. Just continue with your normal pool chemistry and write on the chalkboard 50 times, "I will not put Simple Green in the pool".
    Apr 2015
    Charlotte, NC
    19
    Thank you!
    Polaris 360
    May 2015
    13,199
    Quote Originally Posted by Texas Splash View Post
    Like the time a user wrote in and described dumping a gallon bottle of bleach into his swimming pool one night only to realize that the bottle was full of used motor oil instead fresh bleach....yeah, definitely a lot worse stuff has happened...
    Matt
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Simple green is mild compared to my slinging a brand new running gas blower into mine...
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Apr 2015
    Charlotte, NC
    19
    How would someone do that without noticing? By doing it in the dark, or by being visually impaired? I would think even in that case the smell would get your attention. Wow, I feel a little silly now for worrying about a little Simple Green.
    Polaris 360
    Quote Originally Posted by tempestuous View Post
    Intoxicated? I know I'd be able to tell just from the way it slashed in the bottle.
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
