Results 1 to 20 of 20
Thread: South florida pool - finalizing contract
    Apr 2016
    Coconut Creek/FL
    7
    Hey all,
    I am new to the forum, but am loving all the advice and help I have found so far. My wife and I have debating about building a pool for quite some time now, and have finally opted to go for it. We have spoke with a few companies and have made our decision on one, I wanted to include our estimate for the pool to get your thoughts on if there is anything I am missing by chance, and if the quote seems decent. Thanks again for all your help, and looking forward to taking you all on this journey. Please see below quote:
    Parkwood Pools Advantage Program
    Scope of work
    27’X15’ Lagoon
    STRUCTURAL:
    · STEEL REINFORCING THROUGHOUT STRUCTURE TO MEET
    · ASTM NO.A615
    · GRAVEL ROCKBASE FOUNDATION FOR DEEP END POOL SHELL
    · GUNITE CONCRETE SHELL TO MEET OR EXCEED LOCAL BUILDING CODES
    · MIMIMUM 8” GUNITE WALLS & FLOORS
    · GUNITE STRUCTURAL PERIMETER BOND BEAM CONSTRUCTION
    · PRE- BENT STEEL LOOP TIE IN’S 9” ON CENTER FOR BOND BEAM TO WALL STEEL
    · GUNITE STEPS IN SHALLOW END OF POOL
    · GUNITE EXTENDED BENCH IN DEEP END OF POOL (SWIMOUT)
    · LIFE TIME STRUCTURAL WARRANTY
    PLUMBING & HYDRAULICS:
    · SCHEDULE 40 NON-CORROSIVE PVC PLUMBING
    · BACKFILL OF CONCRETE SHELL AND PLUMBING LINES
    · ANTI-VORTEX SINGLE CHANNEL DRAIN ( NEW SAFETY DRAINS)
    · INDEPENDENT POOL CLEANER LINE WITH SPRING LOADED SAFETY CAP
    · AUTOMATIC WIDE MOUTH SKIMMER ENCASED IN GUNITE BEAM
    · MINIMUM 3RETURN LINES FOR CIRCULATION, 3 RETURNS IN WAL FOR HEATING AND CHEMICAL CIRCULATION
    · HYDROSTATIC UPLIFT VALVE WITH UNDERDRAIN STUB OUT FOR FUTURE DRAINAGE
    · HOOK –UP & PRESSURE TEST PLUMBING LINES FROM FILTER TO POOL 50’ PIPE RUN
    · OVERFLOW LINE FOR CONVENIENT AUTO DRAIN
    · SMALL MACHINE ACCESS CUSTOMER TO SUPPLY 6’6” ACCESS
    EQUIPMENT & FINISHES
    · 100 WATT LIGHT, WHITE OR BLUE LENS
    · 6” BAND OF CERAMIC WATERLINE TILE & BULL NOSE BRICK BORDER COPING
    · JANDY CS200 CARTRIDGE FILTER WITH A 2 SPEED 2 HPJANDY PUMP TO MEET NEW 2010 BUIDING CODES
    · DELUXE UPGRADE AGGREGATE POOL PLASTER FINISH
    (CLI-SUNSTONE) WITH A REAL 10 YEAR WARRANTY
    ELECTRIC INCLUDES:
    · PLANS, PERMITS, LABOR, AND ALL MATERIALS INCLUDED. TIME CLOCKS AND LIGHT TRANSFORMERS, AND INSPECTIONS. HOOK UP TO EXISTING PANEL.
    · PRE-FILTER SYSTEM TO PURIFY INITIAL START-UP WATER
    (CARBON TANKS). SO YOU ARE READY TO SWIM.
    · JOB SITE: CLEAN UP AFTER EACH PHASE OF CONSTRUCTION.
    · COMPLETE INITIAL CHEMICALS START-UP SERVICE & OPERATING INSTRUCTIONS. (POOL SCHOOL )
    · ALL NECESSARY CONSTRUCTION & FINAL INSPECTIONS REQUIRED BY MUNICIPALITY PUBLIC LIABILITY AND WORKMAN’S COMPENSATION INSURANCE
    · POOL FLOATATION , CONSTRUCTION PROPERTY DAMAGE & NEGLIGENCE INSURANCE
    · $1,000,000 TO $ 2,000.000 UMBRELLA INSURANCE POLICY
    ANNIVERSARY CHECK UP
    · COMPLETE QUALITY SYSTEM CHECK UP( POOL & EQUIPMENT )
    ONE YEAR FROM COMPLETION DATE
    WARRANTIES:
    • Lifetime Transferrable Structural Warranty (Parkwood Pools)
    • Lifetime Filter Warranty (Jandy)
    • Lifetime Valve Warranty (Jandy) Against Leaking, Breaking, & Pressure Loss or Slip
    • 5 Year Heat Pump or Gas Heater Warranty (Jandy) (If Purchased)
    • 10 Year CLI (Sunstone) Warranty
    • Lifetime Pump Housing & 3 Year Motor Warranty (Jandy)
    INCLUDES:
    OVERSIZED POOL 27’X15’
    SUNSHELF/ TANNING LEDGE $2,000. *** NC
    2 Bubblers on sunshelf w/ Umbrella mounting device $700. ***NC
    Swim Out Oversized Deep End $600. ***NC
    Upgraded Jandy CS-200 Filter $900 ***NC
    Over 800’Pavers Pkg includes $ 4000.00
    Upgraded Jandy 2HP 2 Speed Pump $1200 ***NC
    LED Programmable light show @ $1050.00 ***NC
    2 Massage Therapy Jets on Swimout ***NC
    Outline Steps And Benches with accent tile $500.00 ***NC
    Small equipment access shuttle $600.00
    YOUR PRICE WITH PAVER AND OTHER DISCOUNTS ****$25,400.00
    Apr 2016
    Coconut Creek/FL
    7
    Re: South florida pool - finalizing contract
    Apr 2016
    Coconut Creek/FL
    7
    38,300
    What is the depth?
    Funny they call it an over-sized pool and the volume is likely less than 10k gallons
    $1200 for a 2-speed pump? Seems like a VS pump should cost that much.
    What are you doing for a cleaner?
    Feb 2014
    Sarasota
    43
    How about a saltwater generator? Structural footer for potential cage down the road? It says electrical to existing, but typically you have a secondary panel, which I upgraded the breaker and wires for potential future heat pump. Price seems to be in line, but with a tanning ledge it brings the size of the actual swimming area down alot. Also before I signed the deal I would get a timeframe in writing. Is this for a pool that will be ready by August, or being dug by August?
    11,000 gallon gunite kidney pool. Krystal Krete blue pepper interior finish. Pentair Superflo VS pump, Pentair Clean and clear RP 100 filter. Goldline blue essence with T-15 SWG. Savi sol LED. 4 deckjets
    Apr 2016
    Coconut Creek/FL
    7
    Thanks for the feedback all!!
    Crazy I actually forgot to ask about the depth of the pool, I know we talked about it when he was here measuring but did not get anything in writing. Would like to keep it between 3-6 ft from shallow to deep end. He quoted be an extra $1k to make it a salt water pool, said they "were running a sale" that it typically costs $1,800. The more I read about the benefits of the salt water the more I am leaning in that direction, does an extra $1k sound fair?
    I will make sure I inquire about there being a separate panel, he did say he will wire it for a pool heater for me, but said I'd be better off buying after the fact as his run around $3,800.... He did say it takes 6 weeks typically for permits and HOA approvals to come back, and that they can have the pool completed 6 weeks after they get the OK from city and HOA. Said we would be swimming by August
    Do you all think the pool is going to be too small with the tanning ledge? If so any thoughts/recommendations on how we fix this? Thanks again for all your feedback!
    38,300
    Well, personally I do not see the point of a tanning ledge, but that is just me. Easy to have floating lounge chairs to have the same effect, plus have more of a pool to play in.
    Dec 2015
    Palm City, FL
    71
    RC-
    Pool looks nice! Nice yard and view as well.
    I'll second looking at a saltwater generator.
    At first glance the quote seems reasonable for South Florida.
    We're building further up the coast from you and I can confirm that the advice given here often to get multiple in writing quotes is really the one way to ensure your pricing is fair and inline with costs in your area. In our bid process this year our three finalists were all within 5-10% of each other apples to apples except for the decking. There seemed to be bigger discrepancies on this pricing based on their specialty and volume (paver vs. acrylic vs travertine). Maybe keep that in mind if your still thinking about your decking.
    Confirm that demo of the existing patio is included in the price if that's a requirement.
    Sun shelf is a personal preference (we like) and if you have kids I'm sure it will get used. If space and budget allows maybe think about bumping that area out of the main pool area more for extra swimming room though.
    Also as learned here:
    Confirm part numbers for the equipment.
    Confirm # of lights/details on the light show line item, etc.
    Confirm umbrella sleeves for sun shelf or deck area (usually a cheap cost to add)
    Confirm what's excluded from the quote and your responsible for; sod, irrigation, fencing, cleaning/maintenance kits (brushes, vacuum, robot, etc) surveys, HOA submission, etc.
    21,405 gal., 16' x 22' x 36' SWG gunite pool, 6' x 9' flush spa, 18" raised bond beam w/ 3 24" sheers, 4 globerite LED, silver travertine coping/deck, Florida Stucco triple "blue gem" quartz finish, IntelliChlor IC-40, Pentair CC 200 cartridge, Thermeau Prestige TH125 heat/cool pump, Pentair 2-speed 2 HP Max-E-Pro (pool/spa), Pentair Supermax 1.5 HP (feature), Easytouch 8 w/ app/remote, Dolphin S300i robot
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Quote Originally Posted by MayorHanna View Post
    RC-
    What this says ^^^^^^^^^^^^
    Mayor Hanna? Are you after my job? LOL if so you are doing a fine job! You did a great job!
    Kim (sitting back relaxing after Mayor Hanna did all of the work for me hehe)
    Dec 2015
    Palm City, FL
    71
    Quote Originally Posted by kimkats View Post
    No way. I was responding on the quote and decking but heard whispers in my ear which led to the rest.
    I thought I give my Florida neighbors some attention as payback for all the help I've gotten but now I'm exhausted after responding . Maybe I'll concentrate on TFP people who own pools and live within a five mile radius. You handle the rest.
    Jul 2012
    Tallahassee, FL
    30,525
    LOL LOVE IT! I will tell you this, helping on pool builds are SO much fun AND you learn so much! PLEASE look for and post to any and all threads you see! We can tag team them!
    Kim
    Dreynolds's Avatar
    May 2015
    Palm Beach Gardens, Fl
    190
    Make sure that quote includes the depth you want. Many pool builder up the price for deeper a pool.and make any changes you what before you sign.Many PB give a fair qoute until you get to the nuts and bolts of what you want. I wish I would have done that. We wanted a darker finish and they charge a lot for that. Also were is your tile allowance? I had 6.00 per sq ft. Tile can get pricey. So make sure you know what you are getting there. And are the light LED? I love my LED color lights. Make sure you like the paver they are including in your qoute, if not what the charge for upgrade.just a little of the thing I learn after the fact. Anything you think you might what get a price in writing on now. And good luck with your build.
    17x 30 rectangular pool 17x5 splash pad, with rasied spa 6x5 with spillover built October 2015. Quartzscapes Barbados blue finish. Jandy 1.5 horsepower 2 speed pump. Jandy aquapure SWG. Gulfstream heat pump with chiller. Great White vacuum. T-100 test kit.
    Apr 2016
    Coconut Creek/FL
    7
    Hey guys,
    Thanks for all the great info and advice. We are going to move forward with Parkwood Pools, we signed contract yesterday and I was able to get all these questions answered. PB indicated we should get draft back from engineering sometime next week, we can than move forward with applying to HOA and ultimately the city of Coconut Creek. I kinow cities vary on approval timeline, but any of my Florida brethren out there how long did your permits take to come back?
    Thanks again!!!
    We have PB making sun shelf smaller as well. Original design was for a 12 ft long sun shelf, we are pulling back to 8 ft... We do have two small children and think the sunshelf would be great. Also, on nothing sounds better to me than relaxing on a sunshelf, drinking a beer, and listening to some Bob Marley...
    Asking PB now how much more travertine is going to run me as well... Price includes 800 ft of pavers from a company in South FL called Gem Pavers... Not sure if I'm loving the paver look though and am starting to lean more towards the travertine look....How much extra did the travertine cost you all out there that decided to upgrade?
    Apr 2016
    Coconut Creek/FL
    7
    Also, for pool heater do you all recommend gas or electric?
    Dec 2015
    Palm City, FL
    71
    Quote Originally Posted by rcmancebo View Post
    Hey guys,
    We're waiting on permits currently:
    Martin County - 3 weeks and counting...
    HOA - 2 weeks and counting...
    My kind of pool..Marley or Matisyahu would work...
    Here are the numbers we received from the three final apples-to-apples quotes we received based on ~1100 sq.ft. decking:
    PB #1
    $9/sf concrete acrylic decking with footers
    $13.50/sq.ft. travertine no footers
    PB #2
    $9.50/sf concrete acrylic decking with footers
    $14/sq.ft. travertine no footers
    PB #3
    $9/sq.ft. travertine with no footers
    $11/sq.ft. for acrylic decking with footers
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    Wait - they will build a pool with pavers for 25,400? With 800 sqft pavers, LED lights, swim outs and massage therapy jets? That is some deal you got. I think Florida and Arizona have the best deals. I am so jealous. In my area, PB's run away when you tell them that the budget is 30 to 40k.
    I still believe that the pool cost should not exceed 10% of the cost of the house - wonder if there is some thumb rule like that.
    Geometric pool with all Pentair equipment. Raised spa - 18" with Artic Lagoon 1" glass tiles. 3HP VS Pump, 2 skimmers, 6 returns, IC40 Salt system, Easy Touch 8 with LED color light in pool and spa. 1200 sqft of Marble White Pavers decking in Versailles pattern. Tiling and coping almost completed, Indigo Blue Prism Matrix plaster. Pool Build Thread: Houston (Katy) Pool Build - Started April 2016
    Dreynolds's Avatar
    May 2015
    190
    I have Gulfstream heat pump with chiller. Heat pumps cost more but I understand they are more Energy efficient. Plus a chiller is nice with the heat in the summer in south Florida. We went with travertine and we love it. Here is a pic of the deck
    Mar 2013
    New Hampshire
    351
    Things seem to be cheaper in FL. 800 sq ft of pavers cost us $12,000 here in NH. Now add in pool, SWG, electrical etc and it got expensive pretty quick.
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    Apr 2016
    Coconut Creek/FL
    7
    Quote Originally Posted by Dreynolds View Post
    Love your pool!! Just curious who you all used as your PB and if you dont mind sharing costs... thanks!!!
  20. Back To Top    #20
    Nov 2017
    fort lauderdale fl
    24
    did you end up using parkwood? considering using them...curious how it went and how the pool is holding up a year or so later...
