Results 1 to 9 of 9
Thread: SWG Percentage
    Ubrucen's Avatar
    Apr 2016
    Vancouver
    32
    SWG Percentage
    ~16,000 gallons
    IG vinyl
    sand filter - hayward pro series
    SWG
    I'm lost & confused. The SWG pool we inherited when we moved is set at 10% chlorinator. I'm finding the need to "super chlorinate" after a day or so use to keep up with chlorine levels. Should I increase the overall chlorinator percentage? Or is 10% a good default? The filter has been running a lot in order to heat the pool (Vancouver weather has been amazing and have recently been using the pool for 3-5 days consecutively). And is the super chlorinate option ideal to bring up chlorine? Or should we use chemicals? Our CYA was low but now in range.
    Also just a curiosity- there's a lot of white streaks/ stains on the pool liner from previous owners. What can I do to avoid creating more?
    Thank you
    38,267
    Re: SWG Percentage
    How long are you running the pump?
    What is your CYA level?
    Sounds like you should certainly raise the % output, and you should use bleach to quickly raise the FC instead of using the super chlorinate function.
    The streaks could be a number of things.
    Please post up a full set of test results from one of the Recommended Test Kits.
    Also, Please add your pool details to your signature as described HERE as it will help us help you.
    Ubrucen's Avatar
    Apr 2016
    Vancouver
    32
    Re: SWG Percentage
    The pump is running 24/7 right now. CYA is about 70. Is there a threshold % output that you wouldn't want to cross? And is there a drawback to using super chlorinate?
    understood - I'll update my specs and post results soon. Thanks for your help!
    38,267
    Re: SWG Percentage
    Well, if I knew the pool size and the SWG model, then we could calculate how many ppm of FC you are adding daily and see if it is reasonable.
    Why are you running 24/7? That is just a waste of money if you are not in a SLAM process of something.
    Ubrucen's Avatar
    Apr 2016
    Vancouver
    32
    Re: SWG Percentage
    We've been running it to keep the temp up - at night average temp right now is 51 degrees F and during the day it has ranged 67-86 air temp.
    So basically it's a just under 16,000 gallon pool, Turbo Cell T-Cell 15. I tested chlorine (with a test strip... I'm ordering a kit) this morning and it went from on the lighter side to practically non existent about 12 hours later. Your help is appreciated!
    EDIT: my next post will have signature as follows:
    16,000 IG Vinyl, Hayward Pro Series Pump, Sand Filter, Turbo Cell T-Cell 15, Hayward Super Pump (and 2 more pumps for for Slide, Waterfall, Powerfall)
    38,267
    Re: SWG Percentage
    Do you have a heater? Because without one I do not understand the point of running the pump 24/7.
    The T-15 at best generates 1.45 pounds of chlorine gas running 24 hours at 100%.
    In a 16k pool that is 11ppm of FC.
    Running at 10% is only adding 1.1ppm of FC into the pool daily.
    A typical pool needs 2-3ppm of FC added daily.
    Ubrucen's Avatar
    Apr 2016
    Vancouver
    32
    Re: SWG Percentage
    Thanks. Yes we have a gas heater which is why it's running so much right now. So from what you've explained, I should increase output to about 20-30%. I'll start on the lower end and see how goes. During times of inactivity we'll be running the pump about 8 hours per day- should the chlorinator percentage be adjusted up or down?
    Lastly, when is it safe to re-enter a pool after super chlorinating?
    Again, thank you Jason and all.
    16K IG Vinyl, Hayward Pro Series Pump, Sand Filter, Turbo Cell TCell 15, HaywardSuper Pump and 2 more pumps for for Slide, Waterfall, Powerfall, Hayward TigerShark cleaner
    38,267
    Re: SWG Percentage
    If you only run 8 hours, then your SWG output might need to be up around 60-80% to add enough FC. The level of FC you have to maintain is a function of your CYA level.
    It is also the CYA level that determines what the safe FC level is. Anything under shock FC level is safe.
    Flbeachluvr's Avatar
    Mar 2016
    Port Orange, FL
    363
    Re: SWG Percentage
    For my 9000 gallon pool I run my pump and SWG for about 6 hours a day and have my output currently set at 70%. My FC last night was 7 so I will probably need to bump the percentage down a tad as my CYA is right around 80.
    Pool completed 3/21/2016
    8800 gallons, plaster 14' x 24', 3/4 hp Hayward pump, Hayward cartridge filter, Blue Essence T-5 SWG, Kreepy Krauly Kruiser, Taylor K-2006 test kit with Speedstir, Taylor K-1766 salt test and 250 sq. ft. of Heliocol solar panels with Pentair Solartouch control system
