Results 1 to 10 of 10
Thread: First time pool owner -swg question
    Apr 2016
    iowa
    20
    I'm new to the pool world and have done some research and think I have a pretty good handle on the chemistry side of things. One question I do have, if my SWG is set to run x- amount of hours a day per the pool size. Do I need to be concerned about turning it down on weeks or longer period of times when my pool will be unused ? I plan to have my pool covered and there will be a time when it goes unused for several days. My thinking says that if it is covered and unused that I will get a spike in chlorine if the swg continues to run on the normal schedule.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: First time pool owner -swg question
    Welcome!
    If it's covered, you won't lose much FC to sunlight, so yes, turn down the SWG% or the filter run time. Be aware that any CC that develops also won't get broken down by sunlight when it's covered, so don't be alarmed if you pull off the cover and test things and CC has jumped. It'll probably all be gone by the next day.
    Apr 2016
    iowa
    20
    This is a little off topic but I have read some places, for a new pool start up you need to do a shock treatment and other places including my SWG manual to just boost the SWG for a unspecified amount of time. I have a 6000 gal pool a 1500 GPH pump and a SWG capable of 15000 gal pool and can produce 12g an HR of chlorine. Do I need to shock first because will it take to long to get the chlorine levels up ? or will my SWG take care of it ?
    Richard320's Avatar
    Jan 2010
    18,966
    Quote Originally Posted by jaspers_87 View Post
    If you're filling it from a public water supply, there's no reason to shock it. People drink that water. They bathe in it.
    We suggest people start their pools as a bleach pool and get things balanced before adding the salt. The salt dissolves for a day and you just turn on the SWG and let it carry on from there.
    Apr 2016
    iowa
    20
    what order should I go about balancing things out - alkalinity-PH-Chlorine-CYA-CH-salt ?
    How far off the recommended levels is my tap water going to be?
    If you recommend starting with bleach what or where is the figure that tell me how much I need to add.
    Sorry for all the questions, seems like its easier to get it right the first time when starting up rather than fixing a mistake.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    That order is good except skip TA for now.
    Need to test to find out, all water is different.
    How to determine how much bleach to add is covered right here, Pool School - ABCs of Pool Water Chemistry
    Please add your pool info to your signature so tha we can better help you, more here, Pool School - Read This Before You Post
    I just read back through and see you have an SWG, here is an additional page covering that, Pool School - Water Balance for SWGs
    Richard320's Avatar
    Jan 2010
    18,966
    If you post your test results, we can walk you through it.
    What to add and how to add it is covered in Pool School - Recommended Pool Chemicals
    How much to add is explained in Pool School - PoolMath
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Good one Richard!!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Apr 2016
    iowa
    20
    Thanks guys!!!!..... I have added Sig info and started reading pool school and answered some of my own questions. I will post up my test results as soon as I get my pool set up and filled
    6000 gal
    AG
    Cartridge Filter
    15000 gal SWG 1500GPH pump
    Install Date TBD
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    You're in good hands Jaspers_87
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
