Thread: Intel skimmer upgrade/plumbing questions
    SunnyBama's Avatar
    Feb 2015
    Birmingham, Alabama
    21
    I will be installing a through wall skimmer on my Intex pool; any suggestions as to the best location for the skimmer? I'm also considering turning the original intake into a 2nd return; has anyone had success (or problems) with that conversion?
    Intex Ultra Frame 20'x52" pool (10,600 gallons); Sand filter (Model SF80110); Krystal Clear SWG (Model CS8110); AquaBot PoolRover Jr. Pool Cleaner; TF-100 Test Kit with SpeedStir
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    Re: Intel skimmer upgrade/plumbing questions
    Others who have done this mod will hopefully chime in soon, my post should bring your question back to the top. I would think you put the new skimmer where your current pump inlet hoses are so that you have circulation but I would wait for the experts who have done this.
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,526
    Sorry no one has gotten back to you yet. I installed mine right where the old port was.
    It's best to put it where your prevailing winds will help to push debris into it.
    In hindsight, I wish I had put it off to one side a little bit, so I could do as you mentioned and still use the old port as a 2nd intake below the water line. I would have rigged a valve so that I could use either one or both independently.
    Maybe next time. I might still be able to rig something here to do that, but just haven't felt that industrious yet.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    two words.... down wind
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
