Results 1 to 8 of 8
Thread: SWG slamming
    SWG slamming
    Hey guys, so this is my 2nd season with having a pool to SLAM and had a few questions.
    I reread the SLAM process and just realized something, for SWG, the recommended CYA is between 70-80. However in the SLAM process it says the most effective CYA level for an outdoor pool is around 30-40. So should i be raising my CYA to 30-40 and go through with the SLAM or raise my CYA to 70-80 then SLAM at that point. Obviously it would require ALOT more liquid bleach to get it up to 28 and maintain it. Anyhow, sorry for the dumb question. Cheers!
    Brian, Pool newbie in Atlanta, GA. 24k IG vinyl pool, Circupool SI-45 SWG (purchased 3/2014) , Hayward Pro Series Sand filter S220T, Pentair 1hp 2-speed superflow (thanks Jbizzle!), TF-100 test kit w/ SpeedStir
    Removed -> Hayward 1HP Super pump SP-1607-Z1-M
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: SWG slamming
    When you SLAM, you're using bleach. So you have a bleach pool. SLAM at 30 CYA if you have a choice. If your CYA is 50 already, then you adjust to that. If you're adding CYA, go to 30, SLAM, then raise CYA afterwards and adjust salt levels and so on.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,526
    Re: SWG slamming
    Keep your CYA at the lower level until you complete the SLAM. Then you can raise it to 70-80.
    The only reason for the higher CYA levels for an SWG is that they produce chlorine at a slower, steadier rate. So you don't have to worry as much about all of your chlorine getting bound up by the CYA. But it will be much more effective and cheaper to SLAM at the lower level, since you'll likely be purchasing bleach to do that with.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Re: SWG slamming
    Sorry guys, i should have mentioned it, yes I will be SLAMming with liquid bleach (thanks kroger and aldis for cheap bleach!). But you guys answered my question perfectly nontheless. (and you saved me yet a huge bundle o cash) This is another reason I do not regret becoming a lifetime supporter of this VERY WONDERFUL site! Thanks guys!
    Oh, one other thing, just for clarity, i should treat the pool as a non-SWG until its clean and OCLT is < .5. Once i get to that stage I put in the salt and raise the CYA to 70-80 correct?
    Richard320's Avatar
    Jan 2010
    19,004
    Re: SWG slamming
    Quote Originally Posted by rarenomad View Post
    Exactly.
    Re: SWG slamming
    If i werent a man and married id kiss you, thanks rich and company!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,493
    Re: SWG slamming
    You can still give him a
    Re: SWG slamming
    Nah, that would be creepy
