Thread: 20+ inches of Rain OUCH
    Jan 2016
    Houston/TX
    10
    Post 20+ inches of Rain OUCH
    Well my first problem as a new pool owner. Being an avid aquarium owner water chemistry not a problem until you flood your entire back yard with 20+ inches of rain and 6 drains can barely keep up with getting rid of run off.
    Now when I first filled my pool from my water hoses the pool was a pale green color due to the nasty water from the city of Houston and the aqua color of my plaster. however we had up until now a nice clear aqua blue lagoon look. Today it is more of a sea green toilet. I brushed and there is a lot of sediment which I believe is adding to the color an NOT algae but who knows.
    I did go ahead and add some liquid chlorine to shock since all that sediment was in pool.
    Pool Chemistry
    FC 3.5 Before Shock FC 14 After
    CYA 30 - 35
    PH 7.4
    ALK 100
    CALC 270
    BORATE 50
    Anything else other than running filter 24 hours I should be concerned with our just good old patience. Did I mention I might be a bit OCD
    Thanks all. Houston got hammered today. hope everyone is safe.
    33' x 21' + SPA, Approx. 20k Gallon, Gunite, Freeform, Natural Rock Features, PebbleTec Tahoe Blue Plaster;
    Hayward SwimClear 425, 400k heater, EcoStar Variable Pump, 1.5h Booster Pump, Polaris 280 Cleaner, Autofill;
    Jun 2014
    15,249
    Re: 20+ inches of Rain OUCH
    I was just helping another member from your area as well. You're on the right track with a SLAM/Shock FC level and running your pump longer. I would also keep an eye on the filter psi just to ensure it doesn't go too far past a 25% increase in pressure. But you're correct ... it's just going to take some time. Manually clean what you can, then let the bleach and filter do the rest.
    38,520
    We do not "shock", we follow the ShockLevelAndMAINTAIN Process
    Just try to remove all the debris and keep the FC level elevated.
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    Sorry to hear about the flooding, it sounds really bad. Stay safe, the pool can be corrected.
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Jan 2016
    Houston/TX
    10
    Thanks. Sometimes its good just hearing you are on the right path.
    Just looks like I might need to add some more drains to prevent in future if that is even possible.
    Jan 2016
    Houston/TX
    10
    Pool looking better already still a ways from crystal clear. Brushing silt to drains a few times and continue to monitor FC. Looks like this upcoming weekend will be a busy pool and filter cleaning day.
