Thread: Tanning Ledge
    Apr 2016
    Sebring FL
    1
    Tanning Ledge
    Pool is currently under construction but I want to put umbrella sleeves in the tanning ledge. Where do I buy the actual umbrellas and/or tables that go there, or are they just regular patio umbrellas? What size hole needs to be drilled?
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Re: Tanning Ledge
    I was never able to find "in water" or "tanning ledge" specific umbrellas. The consensus seems to be to use standard patio umbrellas that have powder-coated or anodized aluminum poles. No steel, it rusts, and no wood, it expands and gets stuck. Apparently, most umbrellas also have a standard pole width of 1.5 inches. We got our umbrella from Amazon and it fit perfectly. As for what size hole to drill, not sure. I would select an umbrella sleeve that matches your decor, and then follow the instructions. Our PB installed our sleeve.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
