Thread: Anyone else have leaking actuated valves?
    38,345
    I have a Pentair solar 3-way valve that is controlled by an Intermatic actuator.
    What was a drip ever few seconds has not turned into a near constant stream out through the shaft area.
    While doing pad maintenance, I took the valve apart (which looked fine), used a generous amount of silicone grease on the 2 shaft o-rings and put it all back together. Seemed to basically stop it at first ... until the actuator started moving again.
    If I do not install the actuator, I have no leaks at all.
    It almost seems like the actuator is not properly aligned and is putting sideways force on the shaft making it leak?
    The first Intermatic I got ended up having a crack internally, so the shaft would wobble and not hit the dip switches to stop the rotation. This is the replacement they sent me and wondering if there is just a design flaw with these.
    Anyone else have a leaking valve problem with Intermatic actuators?
    Are the more expensive actuators any better?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Anyone else have leaking actuated valves?
    I have had small leaks out of my Pentair solar valve before and usually replacing the o-rings helps. But I have found that it sometimes takes a couple of tries before I can stop the leaks. I have Goldline actuators but as far as I can tell, they aren't the cause of the leaks. But I can see how a misalignment could possibly cause a leak.
    Mark
    38,345
    They were leaking last year and I swapped the o-rings from an extra new valve ... did not seem to help.
    AT one point I got the leak to slow down by loosening some of the screws, suppose I might just have to mess with it to see if I can get it to slow down.
    Maybe I will see if I can get them to send me more o-rings, although nothing looks wrong with these.
    Do you recall that there are supposed to be 2 o-rings with a plastic c-ring between them?
    Feb 2011
    Petaluma, Ca
    665
    Same here, my solar valve developed a leak last year, still about the same now, slow drip.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Yes, 2 o-rings with a spacer.
    Mark
