Results 1 to 7 of 7
Thread: Pool store using Waterlink device for chemical levels - is there a consumer option?
    My pool store just started using the waterlink device this year, I have my own test kit and stirrer but I hate checking for CYA since I'm never sure if in doing it right, leaves too much room for interpretation.
    Anyhow the Waterlink was really cool, they just used a syringe to place my water sample in this disposable cylinder and it then spit out a paper with the current chemical readings, although I was surprised that it couldn't do salt levels and they still did that the old fashioned way.
    Anyhow, what is the general opinion on it an do they make an affordable consumer version? Or any other competing product at the consumer level that does the same thing + salt?
    Thanks
    18' x 36" Ovalish 80,000 Litre Vinyl IGP. 2 speed 1HP Hayward pump SP2607X102S. 300 Pound Sand Filter. Summit Sum5 Heat Pump, Goldline Controls Aqua Logic P4 System, T-CELL-15 SWG, Aqua Pod Remote Control, Pentair 7845xx02 light.
    TF-100 Test Kit, SpeedStir Stirrer, Pool Chemist in training.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Pool store using Waterlink device for chemical levels - is there a consumer optio
    If you're not comfortable with the CYA test, you could order the 50ppm test solution from TFTestkits.net Use that to tune your testing procedure and environment. Once you get comfortable with seeing the 50ppm level. Use the same testing environment to test your pool water.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    There are consumer electronic tests like the Lamotte Color Q, but they are not as reliable drop tests.
    Check out this thread ColorQ vs TF100 along with a boatload of others if your search "ColorQ"
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    38,521
    I trust the digital water testers at the pool store less than I trust the teenager squeezing in drops
    Donldson's Avatar
    NW Ohio
    2,917
    That makes two of us.
    If you feel you need to work on your testing skills then get the Standard Solution pabeader mentioned, but if you aren't having algae issues then that tells me you are probably doing a decent job at it.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    30,432
    That makes three of us!! Trust your own testing. Relying on Pool Stores is why 80% of the water chemistry issues end up on this forum.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Just out of curiosity, how close did their readings match your readings?
