Thread: This is the pool package I am looking to get. Want TFP's input
    Jul 2013
    Long Island, NY
    532
    Hi All - I am thinking of getting this pool package either this spring or next spring. Wanted to see if I overlooked anything. Thanks everyone, see below
    1) Saltwater 5000 pool from Pool Factory with Unibead liner (wife doesn't want overlap as she doesn't like the look of it) 15'x52 Saltwater 5000 Round Pool
    2) Pump & Filter combo from Doheny's. (50sq ft cartdige & 3/4 HP motor) I need the 3/4 HP to be compatible to my outdoor timer.
    Doheny's Cartridge Filter System For Sale | Doheny's Pool Supplies Fast
    3) Chlorease AGP saltwater system SmartPool ChlorEase Salt Chlorine Generator A/G Pools - CL01 - INYOPools.com
    4) I will also be buying pool cove, floor pad and wall foam
    5) I will also be buying slice valves so I can shut off the valves to change my cartridges
    I have a solar cover, winter cover, vacuum and ladder already. Thanks
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    38,290
    Re: This is the pool package I am looking to get. Want TFP's input
    I would recommend a larger filter (75+ sqft cartridge or a 13" sand filter) and a 2 speed motor on the pump ... might not come as a "package"
    Casey's Avatar
    SW PA
    10,444
    I would also recommend a larger diameter pool if you have the room for it. Go as big as you can afford and fit into your yard.
    Jul 2013
    Long Island, NY
    532
    Thanks for responding
    Jbizzle - How hard is it to 'mix and match' manufacturers when it comes to pumps/filters. I was going to get the doheny's one since its already attached. I figured for approx 5,000 gals a 50sq ft cartridge would be good
    Casey - I would love to get an 18' pool but where I live on long island the backyards are not too big. It wouldn't fit unfortunately.
    SWG: Intex CS8110
    Casey's Avatar
    SW PA
    10,444
    Can you do an oval?
