Page 1 of 3 123 LastLast
Results 1 to 20 of 59
Thread: First SLAM (woohoo!)
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Peeled off the cover today to some slightly cloudy water.
    CH: 325
    TA: 110
    PH: 8.2+
    Salt: 1800
    FC: 0
    CYA: 40
    Added some MA, going to the store to grab bleach and salt shortly.
    The pool vac is picking up a lot of clear crystals. Is this salt that has settled over the winter?
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    JoyfulNoise's Avatar
    May 2015
    13,198
    Re: First SLAM (woohoo!)
    Salt (NaCl) does not precipitate out of pool water. I would not buy salt if I were you. Your water is likely much too cold for an SWG to run so just manually chlorinate and don't bother adjusting the salt until it is warmer.
    Matt
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    I'll wait on the salt then. I was expecting to need to add some due to dilution.
    Water temp is about 55 now, what is the lower bound for a SWG?
    May 2015
    13,198
    Pentair's cut off at 58-60F. Even so, at low temps below 70F an SWG will not be very efficient. You should check your owners manual but I would just keep the SWG off until your water is consistently above 65F. Manual chlorination will be more than adequate especially at cold water temps since algae is basically dormant at temps below 60F.
    Adjust the salt later and measure it with a K-1766 test kit. The SWG salinity readout is not as accurate.
    I suspect those clear crystals are probably some kind of carbonate scale, like calcium carbonate. Scoop some up and pour a few drops of muriatic acid on them. If they fizzle and bubble, it's a carbonate.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to the SLAM club! I don't turn my SWG back on until the water gets to 70, I manually dose with bleach.
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Added 8 gallons bleach. That's all Aldi had. A local pool store has 5 gallon carboys of 12.5% chlorine that they will deliver for $14.50. I think I'm going to go that route.
    Test Kits:
    My Pool:
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    That 8 gallons only took it up to 10FC. Added another 2.5gallons of 12.5% liquid chlorine from the pool store. Also added another 1/2 gallon MA since the PH did not budge.
    Test Kits:
    My Pool:
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    WOW ... just a few hours later and things are already looking significantly better. Still cloudy but I think it will be crystal clear in no time.
    I added another 2.5gal of 12.5% Chlorine, and a 3rd gallon of MA (PH still off the chart).
    Test Kits:
    My Pool:
    Jun 2014
    15,083
    Now remember, pH gives a false (high) reading when the FC is over 10, so during a SLAM, don't bother testing pH anymore until the SLAM is over or you allow the FC to drop below 10. Other than that, nice! Stay with it though. Don't slack early just because the water looks better. Maintain until you pass ALL 3 criteria.
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Quote Originally Posted by Texas Splash View Post
    I forgot about that, oops.
    Test Kits:
    My Pool:
    May 2015
    13,198
    What's your FC level right now?
    Matt
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    16. I may bump it up a bit more since I think my CYA is closer to 50 than the 40 I said earlier.
    Test Kits:
    My Pool:
    May 2015
    13,198
    Before you do, do this -
    Take a water sample and dilute it 1:1 with DISTILLED WATER. Then test your pH. It should give you a fairly accurate read of your pH.
    Matt
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Just tried. The distilled water had a PH of 7.2. A 50/50 mix still showed 8.2.
    Test Kits:
    My Pool:
    May 2015
    13,198
    Quote Originally Posted by pinguy View Post
    Yup. Distilled water has a pH close to 7 and nearly zero TA. When you dilute your high alkalinity pool water with it, it cuts the FC in half but doesn't change the pH because your pool water's alkalinity absorbs the excess hydrogen ions from the distilled water...in other words, your water's TA buffers against a pH change. This way, you can get a more accurate read of you pH at high FC.
    So, basically your pH is above 8.2 but that could be temporary from all of the bleach you've been adding. You can keep trying to bring it down or wait until the SLAM is over. Your choice.
    Matt
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Thatls a cool trick. I'll wait for the SLAM to be over to avoid the risk of making an acid bath. I don't think it'll be a long SLAM though!
    Test Kits:
    My Pool:
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Ending the night at 23FC. Looking forward to see what it reads in the AM.
    Test Kits:
    My Pool:
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Looking completely clear this morning (compare the visibility of the main drains from my last pic). I was in a rush because I overslept so I don't know how accurate my counting was, but I think the FC drop was 1 or less. I forget to test CC in my haste. I'm going to push the SLAM one more night to be sure
    Test Kits:
    My Pool:
    Jun 2014
    15,083
    That's starting to look very nice. Make sure you pass the 3 SLAM criteria and you'll have this behind you in no time at all.
  20. Back To Top    #20
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Got it
    I'll make sure to get my rear out of bed earlier so I can get a solid test in tomorrow AM.
