Results 1 to 11 of 11
Thread: Lowered PH to 6.8 is it OK to raise it using just aeration.
    Apr 2016
    Mt Dora FL
    24
    Hello, Im new here, have been reading all the tips and pool school stuff, I really like this site!
    I have a really small pool, 3500-4000 gallons kidney shape.
    Im new to all this. Yesterday I had a high PH and put in the "pool store" recommended amount of acid. Now my TA is 50 and my PH is 6.8. It was 6.4 last night.
    My question is if it is OK to raise my PH with just aeration, or is this an "emergency" low level where I should run out and buy something to raise TA and PH right now. I guess I hear "acidic" and freak out thinking my pool is going to dissolve. My pool is really small and I have raised PH by aeration before just using the single pool jet I have. It only took a few hours to raise it, but it was not as low as it is now.
    Just concerned my pool is going to disappear on me if I do it slowly.....lol
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Lowered PH to 6.8 is it OK to raise it using just aeration.
    Shouldn't take long to aerate that back up into range.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Welcome to TFP!
    Please add your pool info to your signature so that we can better help you. More here, Pool School - Read This Before You Post
    Flbeachluvr's Avatar
    Mar 2016
    Port Orange, FL
    363
    I accidentally added too much muriatic acid to my new pool a couple weeks ago and had similar visions of it dissolving but the next day my pH was back at 8+. I'm sure someone else will chime in soon.
    Pool completed 3/21/2016
    8800 gallons, plaster 14' x 24', 3/4 hp Hayward pump, Hayward cartridge filter, Blue Essence T-5 SWG, Kreepy Krauly Kruiser, Taylor K-2006 test kit with Speedstir, Taylor K-1766 salt test and 250 sq. ft. of Heliocol solar panels with Pentair Solartouch control system
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    I think aeration alone is just fine. 6.8 isn't all that low and should cause any problems. One problem i see is that most ph tests bottom out at 6.8 even if the ph is actually much lower, though you said you measured a 6.4 so maybe it's a pool store number, although that's a number they are generally pretty good at.
    Ph and damage can vary wildly on your pool type though, please try to update your signature with your specifics. I am assuming a fiberglass pool just do to the size. You can do this in the settings at top right then 'edit signature' on left side middle of the page.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Apr 2016
    Mt Dora FL
    24
    Ive edited my sig twice and for some reason it isnt showing up??
    edit-
    OK...there it is.
    3,500 gal, in-ground, exposed aggregate, Hayward Maxflo Sp2807x-10 1Hp pump and Hayward Star-Clear C12002 filter. Chlorine liquid.
    Pool Tool's Avatar
    May 2014
    757
    Looks great, thanks.
    Apr 2016
    Mt Dora FL
    24
    Quote Originally Posted by Pool Tool View Post
    Exposed aggregate pool...does that mean I should worry because its not fiberglass? Im aerating right now. It is a small pool, but seems to be really well made.
    Forgot to mention my TA is 50, it seems to go up all the time so thats why I was trying to lower it.
    Jul 2015
    Central Valley CA
    1,109
    You will be fine my PB did a no drain acid wash at a PH much lower than yours for several days and I did not notice any change it the smoothness of the plaster (I checked every day, I had nightmares of all that acid eating my new pool ) I don't ever want to do that again my bet is you will be in range by tonight.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    30,431
    Just reinforcing what others have said.....Your pH will not be low enough long enough to do harm
    DFW, TX
    24,509
    Your TA at 50 is Ok for now. But, if your PH doesn't stay around 7.5 to 7.8 then you can raise it to 60. Long term low PH will cause problems, weeks to months. It is a more immediate problem if you have a heater with a copper heat exchanger.
