Thread: RV Glycol
    Jun 2015
    Ottawa/Ontario
    339
    RV Glycol
    Any trick to prevent the glycol from getting into the pool? Or should I simply ignore it and let it flow into the system?
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: RV Glycol
    There is some minor debate and even some comments/thoughts last year from ChemGeek, a local legend, regarding the antifreeze in the pool. I think the general consensus was that it won't really cause any negative issues if it gets into the pool, but where possible try to direct it away from the pool.
    What I did last year, was to start the pump with the filter set to waste. This cleared up the suction side. For the return side, I opened one return at a time and put my vacuum hose over the open return and directed the antifreeze water into the yard. Once the first return blew for a minute or two, I opened the other return and again used the hose for a minute. Fortunately, I have only two returns so it wasn't too bad. It was a little tedious especially doing it alone but better than seeing the pink cloud blow into the pool.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: RV Glycol
    Just be sure to maintain your chlorine level. It will use up quite a bite of chlorine.
    Jun 2015
    Ottawa/Ontario
    339
    Re: RV Glycol
    Tx both. This is our first opening. We are "weaning" ourselves off PB, but my gut feeling is they will not bother trying to clear the glycol out first.
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    Re: RV Glycol
    Quote Originally Posted by Pool Tool View Post
    I swear, I have tried to think of a way to do this and never thought about the vac hose. I kept thinking about doing something with PVC pipe one return at a time. Always suction side to waste and slide to a bucket, now I have the answer for my returns. It was all right there in front of me. Thanks!!!
    SCon36
    24,000 Gallon IG vinyl pool (16x36x8) with Hayward S200 sand filter and Hayward pump and heat pump. Built August 2011. I use a Taylor K-2005 test kit with a K-1515 add on.
    https://www.youtube.com/watch?v=bIgL...0MyAw&index=29
    Jun 2015
    Ottawa/Ontario
    339
    Re: RV Glycol
    It is a simple and brilliant method. Is there some way to physically attach a vac hose to the return jets? I assume these are easy to find couplings.
